270whp K24A / k20a2 Recipe with dynos
Old 01-19-2007, 09:34 AM
Nikos's Avatar
Default 270whp K24A / k20a2 Recipe with dynos
Greetings,
I will get right to the point. Accord k24a4 is the cheapest k24a motor you can get from a junk yard.. around $600-$1000
Once you have it, you remove the head and remove the pistons and rods and the oil pump too.
JE pistons for $420 off ebay or other online store 13.5:1 compression 87mm
IB spec rods k24a $450
ACL racing bearing set from ERL performance $180
Cometic gasket for k24a 87mm 40/1000
installed
bearings installed
domedomedome!
We had a machine shop drill a hole for an oil cooler on the k24a
and then we put the k20a2 rsx type s head from the previous motor that used to be a k20a2.
Ready to go with the IPS CAMS K2
Car also used a stock RBC manifold (2006 civic Si manifold) and stock Throttle body witht the karcepts.com adapter plate to fit it. Also a k20a2 oil pump was fitted on the k24a block.
Car was started and street tuned to achieve a good A/F and was taken to inlinepro and tuned by Brian Fisher.
Here's a list of interesting dynos of that motor....
First one, on the day of the first tuning session after 10 dyno runs
here we took the car at the local dyno at dyno dymanics near Pittsburg, PA
WE are comparing the inline pro map vs the IPS k2 basemap NOTICE THE 10WHP difference between 2 different dynojets
Here since on the same dyno, we are comparing the same car, same head with different blocks... One was a stock k20a2 with the IPS k2 cams and the other is the k24a built 13.5:1 compression one
Here's a video of a 200whp TSX EG vs a 270whp K24a Civic ...lol 70whp difference can go a long way
http://www.k20a.org/nikosvsmarkstop.MPG
On that video he fast hatch also had 5.02 final Drive which made it even faster. Needless to say after that weekend, I pulled my stock TSX motor and started looking for something better , LMAO
Car run a few times on the 1/4 at Pittsburg raceway which is at elevation 1200ft
Best was 11.7@ 116 with a 1.68 60 ft and 24.5 x 8 x 13 slicks , no traction bar or skinnies
For next year, we are going to try something more aggressive to get us in the low 11 region.
I made a decent attempt to cover everything but ask away if you have any questions
Old 01-19-2007, 09:36 AM
Dac
Dac's Avatar
That is bad *** man! I would love to have a k.
Old 01-19-2007, 09:53 AM
B A N N E D
kaoss_11's Avatar
real simple setup with big results not bad at all.
Old 01-19-2007, 09:58 AM
Nikos's Avatar
Default Re: (kaoss_11)
Still using OEM springs and retainers with supertech valves
Old 01-19-2007, 10:04 AM
SlepT ej6's Avatar
Sikkkkkkk
Old 01-19-2007, 10:40 AM
Dat1BVtecN's Avatar
Default Re: 270whp K24A / k20a2 Recipe with dynos (Nikos)
the dome on those ****** pistons are nuts!!! nice man
Old 01-19-2007, 10:44 AM
BARTEG's Avatar
Default Re: 270whp K24A / k20a2 Recipe with dynos (Dat1BVtecN)
Old 01-19-2007, 11:25 AM
MikeSarr_GSR's Avatar
Default Re: 270whp K24A / k20a2 Recipe with dynos (Jdmdc2type-r)
I assume this motor is tuned with k pro? What octane requirement
does this engine have... is it ok to run 91?
Old 01-19-2007, 11:46 AM
Revi's Avatar
Default Re: 270whp K24A / k20a2 Recipe with dynos (MikeSarr_GSR)
What year accord is the k24a4 from?
Old 01-19-2007, 12:01 PM
New User
williejohnson's Avatar
Default Re: 270whp K24A / k20a2 Recipe with dynos (Revi)
that car is a tire burner
Old 01-19-2007, 12:09 PM
been there done that
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeSarr_GSR &raquo;</TD></TR><TR><TD CLASS="quote">I assume this motor is tuned with k pro? What octane requirement
does this engine have... is it ok to run 91?</TD></TR></TABLE>
i'd like to know too
also what header and exhaust was used?
Old 01-19-2007, 12:25 PM
Nikos's Avatar
Default Re: 270whp K24A / k20a2 Recipe with dynos (doood)
dtr fab header 4-2-1
kteller 3 inch exhaust
Hondata K pro
on 93 it run 11.9
on 50-50 mix 110-93 11.7
Have a tune for pump gas with nice a/f ratio and one for race gas for the track
Old 01-19-2007, 12:38 PM
cute little bastard
SkoundrelUSA's Avatar
you makes my motor sad.
Old 01-19-2007, 12:42 PM
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos &raquo;</TD></TR><TR><TD CLASS="quote">dtr fab header 4-2-1
Hondata K pro
on 93 it run 11.9
Have a tune for pump gas with nice a/f ratio and one for race gas for the track</TD></TR></TABLE>
very nice. did you guys have to take any extra precautions to rev it that high?
Old 01-19-2007, 12:48 PM
Nikos's Avatar
No... just IB spec rods
Old 01-19-2007, 02:12 PM
MJ23FE's Avatar
It's sick how simple it really is.
-Jalal
Old 01-19-2007, 03:08 PM
mgags7's Avatar
Default Re: (Nikos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nikos &raquo;</TD></TR><TR><TD CLASS="quote">Still using OEM springs and retainers with supertech valves</TD></TR></TABLE>
Note that the stock k series springs are almost as stiff as aftermarket springs for other engines.
Good tutorial, though I don't see how its any surprise that this thing makes 270whp. 99mm stroke, 13.5:1 compression, baller cams, a good intake manifold, and a baller header.
There are plenty of 95mm h22s making this kind of power....you can get similar results with a port on the h head, the k just plain outflows it from the factory, though with a good valvejob, the h head can flow the same as a K.
I wish honda would have made an oem 99mm crank for the h22.....didn't I hear something about putting a k crank in an h22 one time??
Old 01-19-2007, 03:41 PM
MJ23FE's Avatar
Default Re: (bb4ever)
I wonder what this setup would make with some IPS-Kme 8620's and a BETTER intake manifold.
That'll be sick to see!!!
-Jalal
Old 01-19-2007, 03:49 PM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb4ever &raquo;</TD></TR><TR><TD CLASS="quote">
There are plenty of 95mm h22s making this kind of power....you can get similar results with a port on the h head,</TD></TR></TABLE>
i never seen poenty, maybe 1 or 2 h's
Old 01-19-2007, 03:52 PM
mgags7's Avatar
pocketrockets has made some, rlz made john's h22, missing gears makes over 280, not everyone posts up their numbers on h-t
all I am saying is that the H is just as capable of making the same power, with the same parts, short of a head port
Old 01-19-2007, 04:11 PM
ipodhustle's Avatar
all I am saying is that the H is just as capable of making the same power, with the same parts, short of a head port</TD></TR></TABLE>
H series makes 200 lbs of torque with a simple build up?
Old 01-19-2007, 04:49 PM
RudeBwaiSi's Avatar
Really nice.
Re: Video
The EG has 200whp and beat the Civic with 270whp?
Old 01-19-2007, 06:40 PM
MJ23FE's Avatar
Default Re: 270whp K24A / k20a2 Recipe with dynos (RudeBwaiSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RudeBwaiSi &raquo;</TD></TR><TR><TD CLASS="quote">Really nice.
Re: Video
The EG has 200whp and beat the Civic with 270whp?</TD></TR></TABLE>
The green civic pulling away has the 260whp motor described in this thread above.
The civic video taping has a stock (200whp) TSX swap with bolt ons and K-Pro.
-Jalal
Old 01-19-2007, 06:52 PM
StreetEG's Avatar
Default Re: 270whp K24A / k20a2 Recipe with dynos (MJ23FE)
what makes 13.5:1 streetable on a k and not a B?
I love the steelie in the vid on the teal hatch.
you launch in 2nd in the teal hatch w/ the 5.02 final drive?
Old 01-19-2007, 07:01 PM
RudeBwaiSi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MJ23FE &raquo;</TD></TR><TR><TD CLASS="quote">
-Jalal</TD></TR></TABLE>Ok gotcha.
Quick Reply: 270whp K24A / k20a2 Recipe with dynos
