Will ep3 oem axles work on k20a ???
Old 06-21-2011, 09:05 PM
94ej1b16's Avatar
Default Will ep3 oem axles work on k20a ???
So been looking around and searching for the right axle set up for a k20a swaped eg
With hasport mounts.. Heard hasport axles brake and heard ep3 axles work direct bolt on.. So I bought some aftermarket ep3 axles and first test drive and passenger axle snapped from inner hub??? So I really want to know what axles to use or if I can use the ep3 oem axles??? Thanx for any info
Old 06-22-2011, 04:28 AM
kyden's Avatar
Default Re: Will ep3 oem axles work on k20a ???
aren't they 36mm on the hub side?
Old 06-22-2011, 09:17 AM
H-T Premium Sponsor
Hasport's Avatar
where did you "hear" that hasport axles break?
rsx type s axles are 36mm
ep3 and rsx base are 32mm
Old 06-22-2011, 10:00 AM
94ej1b16's Avatar
there 32mm
Old 06-22-2011, 10:03 AM
94ej1b16's Avatar
on line mostly and a buddy that had some hasport axles !!!!!!
DC2-ProdUcTiOnS
05-22-2014 08:38 AM
FRKWOO
04-08-2010 12:01 PM
EduardoDC5
10-28-2008 06:24 AM
TrackSol
06-16-2006 11:28 AM
EF4lyfe
02-28-2005 09:45 AM
Quick Reply: Will ep3 oem axles work on k20a ???
