S2000 Cluster Swap Wiring Guide
Old 09-06-2011, 07:49 AM
  #126
xero_xero's Avatar
Default Re: S2000 Cluster Swap Wiring Guide
Originally Posted by JoHnnY LonGHoRn
Sorry for my terrible grammar first off. I never expirenced any problems or distortions in the conversion. I used that frequency on a few b series setups never had a problem. As far as other setups im not sure but i hope i helped out.
what did you use to calibrate the speed (gps, mile marker and stop watch)
when you change tire size, the calibration is off. tire sizes can distort up to 18%. this means your number can go from p4000 up to p4750.
Old 09-06-2011, 09:21 AM
  #127
JoHnnY LonGHoRn's Avatar
Honestly i stumbled across the frequency via a hondatech archive post, i never saved it but i copied down all the info on my iphone. I keep cross refering the mph on my cluster against my s300 cause it reads vehichle speed, its right on the money, even when i switched my tranny from type R to Ls.
Old 09-06-2011, 11:23 AM
  #128
xero_xero's Avatar
there is a diference in the F/d on an LS and typeR.
just as there is a difference in rotations per mile in 16 and 15 in wheels.
sorry, but you need an accurate speed detection device to get your speed proper.
these numbers are just base numbers, every ones number with be diifferent.
Old 11-04-2011, 05:33 PM
  #129
DAN!!!'s Avatar
Old 11-21-2011, 05:15 PM
  #130
linkdeezie's Avatar
good ****...followed this guide and my cluster is up and runniiiiing....
Old 01-21-2012, 05:57 AM
  #131
1SIKEK4LS-T's Avatar
use a 22 -ohm resistor 12 watt 5% Tolerance For Accurate fuel reading
Old 02-29-2012, 08:42 AM
  #132
weresgyufa's Avatar
Ok but where i must install this resistor? In line to the Clusters B10Pin or in line with the Fuel level meter on the tank?
Old 03-04-2012, 05:42 PM
  #133
kevvvinooo's Avatar
great info! its really helping me as i do my cluster wiring although i found a few things that i thought i should point out in case anyone else is doing it
i'm doing the cluster on my 95 gsr so it applies tio the 94 - 97 dc2
Connector A
Pin 9 is supposed to be red/yellow not red/white
For the wires on Connectors A-D from the s2k pig tails that are not listed, do they not need to be conencted to anything?
As well as wires from Connectors on the integra pig tails including the 3 wires from the 3rd connector which i believe is for the srs since you didn't list it?
Input from anyone is appreciated
Thanks
Old 03-04-2012, 05:52 PM
  #134
DSRxCandyh2bEG's Avatar
I have an s2000 ap1 cluster setup for sale with cf bezel ready for bolt in, looks oem. includes wiring harness, fully functioning and all. PM for info..
sorry for the weak angle, can get more pics...
-Joone N.
Old 03-05-2012, 12:40 AM
  #135
weresgyufa's Avatar
So... a little update, i have installed my AP2 2006 Cluster, but i have some issues, the check lamps wont work :s E-Brake, Check Engine, Oil presure ect ect... I dont Know what is wrong, i have checked all the wires 2 times, but i think i will check it again.
How can i program the Speedohealer, becouse i don't understand it correctly, i have installed it, i drive 32Km and the gauge says its 0.9Km Trip so i dont know, please help.
Old 03-08-2012, 01:39 PM
  #136
siboosted's Avatar
Thought these might be useful to post here.
00-03 S2000 Cluster
Plugs A and B
Plugs C and D
04-05 S2000
Connector A
Connector B
92-95 Civic
EG Connectors
96-00 Civic
Connectors A and B
Connectors C and D
Connectors E and F
94-01 Integra
DC Connectors
Old 08-22-2012, 02:47 AM
  #137
sadam-insane's Avatar
I htink at the Ecu or guage bro... no one has mentioned the tank area.
Hey man this should all be debunked by now... MODIFRY doesnt sell the unit no more and wire worx is banging us in the head for 300 for a peice thats aroung 60 in parts... ]
Has anyone try the Arduino unit and programmign at home and reperesented their findings?/?
Old 10-23-2012, 08:09 AM
  #138
ThaiRacer's Avatar
So i have read about this, just picked up an Ap1 cluster for my ek single cam. its a 98, just wondering I read about people not using the speedohealer and just wiring it up. Is this possible?
Old 10-29-2012, 01:38 AM
  #139
weresgyufa's Avatar
I think it is inpossible, becouse, the Civic use VSS and the S2K's speedometer is a hallseneor and the signal is totaly different. The VSS signal must be converted because the Cluster wont't recognise it, only the tachometer will show right values.
Old 12-31-2013, 07:14 AM
  #140
gabrielsousa's Avatar
how do i power on a s2000 cluster without a car to test ?
Old 01-03-2014, 04:11 PM
  #141
on my CRX ee8 i dont have the:
Guage Lights - Red -- Dash Lights Dim Out
Switched 12v Power - Black/Yellow -- 10. Ignition Key-Red/White
do i need to connect this 2 connections of s2000 cluster (Dash Lights Dim Out / Ignition Key) in other place ?
Old 05-08-2014, 07:35 AM
  #142
anyone has a JDM s2000 cluster ?
the s2000 JDM cluster are limited to 180KPH 112MPH..
anyone has one ?
Old 10-02-2014, 10:21 AM
  #143
thermal's Avatar
Sorry to bring this back up from the past....
-Are there any updates or new units to solve the VSS and water temp readouts?
-Also, I hear 2 things about the gas tank level still. Is this a straight "tap and play" or do I need to install something to read the correct level?
Thank you for your time....
Old 05-17-2019, 10:34 AM
  #144
carrillov80's Avatar
Default Re: (bigcalidave)
Originally Posted by SRACHAD
It doesn't need or have a constant? I've got the schematics from the same cluster your talking about, which is the same i have installed in my car and those pinouts and wires i mentioned above are the ones that run straight to constant power, so that's how i wired them. I believe you about the odometer being stored separately, i have no clue, but i know my schematic shows constant power to B5 and D16. Check it out and let me know if you have those wires listed on your or not and what you think they are for.
As for the VSS, i see where it splits now, So do you think tapping into an aftermarket digital speedometer to get a signal will work? I've got the electrical vss already to get the nordskog guage a signal.
also, the blu/wht wire i see coming from the vss to the cluster and ecm, but what is the yel/blu wire for? it comes from the ecm to the vss.
  • Hi i am installing an s2000 cluster to my eg k series i am runing a k20z3 with magnetic speed sensor i am using kpro but i dont know how to wire the sensor to my speedo or to the ecu can you help me
JHipps
05-05-2014 06:29 PM
LiftoffOversteer
01-17-2013 12:16 PM
slolowoh1civic
Mid-Atlantic (Sales)
17
05-10-2011 12:04 PM
Quick Reply: S2000 Cluster Swap Wiring Guide
