Oil pressure change
Old 11-20-2014, 11:29 AM
carlos8's Avatar
Default Oil pressure change
Hi, My civic Turbo b16a suddenly starts to show 70psi at cold start (from 80psi always). After warm up when running the press seems to work normally to 80psi at WOT.
I'm worried about this cause I only depend on the oil gauge(not oil sensor on the block). I recently replace the head gasket and not drain the water of the block, but I don't think is to much water left after drain the old oil.
What this can be clogged oil pick up or pump going bad?
Any help will be appreciated.
Thanks
Old 11-21-2014, 05:13 AM
carlos8's Avatar
Default Re: Oil pressure change
Come on guys, no suggestions or opinions.
an2ny888
05-06-2013 10:31 AM
b16racereg6
12-26-2010 10:59 AM
tunerkid07
08-13-2007 02:42 PM
BoRiCuA
33
06-25-2004 02:16 PM
civicnightmare
01-19-2004 05:19 PM
Quick Reply: Oil pressure change
