no oil pressure car is knocking like a fat girls jaw bones
ok my car is running but it has no oil pressure i swapped out my oil pump but never "primed" it would this matter? also i tried to cheat and used a used head gasket and there water coming out the sides of the head i figure i will replace the head gasket and prime the oil pimp any other suggestions ???? i miss my car i need it to run and kick *** lol
Unceasing Measure
Re: no oil pressure car is knocking like a fat girls jaw bones (civicnightmare)
so you didn't install the oil pump correctly and reused a bad headgasket which you, no doubt, installed incorrectly. So now here's what's happening: water and coolant are entering your cylinders during the combustion process and oil isn't being cycled in the capacity it should be.
Fix it now and fix it right or your engine is done for.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicnightmare »</TD></TR><TR><TD CLASS="quote">ok my car is running but it has no oil pressure i swapped out my oil pump but never "primed" it would this matter? also i tried to cheat and used a used head gasket and there water coming out the sides of the head i figure i will replace the head gasket and prime the oil pimp any other suggestions ???? i miss my car i need it to run and kick *** lol</TD></TR></TABLE>
Maybe we could help if we knew what you have done to the motor. If you have started a rebuilt motor with no oil pressure chances are you've done too much damage already.
Re: no oil pressure car is knocking like a fat girls jaw bones (Archidictus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Archidictus »</TD></TR><TR><TD CLASS="quote">Fix it now and fix it right or your engine is done for.</TD></TR></TABLE>
yeah don't be stupid and run a motor with no oil pressure. that's just asking for it... ahem.. someone i know..
but your title for this thread was funny
Re: no oil pressure car is knocking like a fat girls jaw bones (nsxmatt)
compression is fine on the car thats why im lost and i only cranked for a split second to do the oil pressure check when i saw it there was no oil pressure it was imediatly turned off maybe 3 seconds if that its a d15 bottom end with a z6 head so thats more than likely the problem then it not being primed is there any other suggestions causing no oild pressure?
A13sechatch
03-30-2011 04:18 PM
hatchinprogress
01-07-2006 07:48 AM
