OBD II to OBD1 questions
Re: OBD II to OBD1 questions (97exracer)
no, no, no.
if you have a obd2 wiring harness you can.. or you can swap the clips. i swapped clips on my altenator. works fine. i drive an integra,so its pretty much the same.
Re: OBD II to OBD1 questions (baonest)
Is there any site that shows the wire diagrams for the 94 Integra and a Civic ex? I'm going to swap the connectors for the Fuel Injectors, Distributor, and the alternater. I'm not sure if there are any more , but I want to make sure about the wires before I start swapping clips.
Is it better to splice or cut the wires?
thanks
thanks
i heart honda
02-13-2009 11:47 AM
IdotheSHOCKER
01-09-2003 07:08 PM
