NEED HELP.DOING H22 SWAP IN EG
Ok 1st off im new to this forum.
Been on here for a while just never registered but now that im doing my swao on my own I figured id go on here to seek for help since ive seen many posts on here and seen member being really helpful.
Ok so I have si hatch..92 model I just pulled out my old gsr swap.had came off a 99 gsr obd2b along with that was from my experience a obd1 harness with obd2 plugs that were wired up such as injectors clips were obd2 alt plug was obd2 and so was dizzy.but shock tower plugs plugged right in my eg chassis harness but I could be wrong..what im doing is a h22 swap. Motor came off a 01 prelude h22a4...im havinf some issues with distributor .plugs.
The h22 dizzy has 2 plugs but is a 01 prelude dizzy..my eg harness has that 1 big single plug which was plugged in to my 99 gsr swap..im trying to use the prelude dizzy I have to plug up tomy eg harness but im confused...I was gonna use the h22 dizzy plugs off the prelude harness that came with motor to wire it up to my eg harness but no wires from dizzy h22 harness plugs match to my dizzy eg gsr harness plug...any help will be appreciated if im being to complicated.om what i posted lmk thank you
