H2B / F2B FAQ
Old 02-16-2012, 06:22 PM
  #276
F2BTorQ's Avatar
Default Re: H2B / F2B FAQ
If anyone still looks at this and they are still wondering what radiator hoses to use check out go-autoworks im going to have them set me up with a radiator and send my block housings in to them to get converted to a/n fittings so i can run any length hose and make any type of setup you want and it looks clean on top of that.
Old 02-17-2012, 04:32 AM
  #277
tecMNSTR719's Avatar
Good deal man.
QSD also makes what they call a "gooseneck" that's pretty much exactly what you're describing. Allows you to use factory hoses instead of trying to find one at a parts store/ets. It's also available with an AN fitting as well:
http://quartersportsdrag.com/GooseNeck.html
Thanks for the info though!
Old 02-24-2012, 12:12 AM
  #278
da9 jdm717's Avatar
ive been doin a lot of reseach on this an i really dont understand it. ok so i have a h22a sh and im tryin to figure out if i can do h2b cause i got to make a braket ether way an my buddy has a h2b kit its an evo kit for cheap an i think i want to do that. but anyways dont the kit come with a half shaft costum plate? an has an1 did this if so can you take a pic of the atts block off plate but if not how should i make the block off plate. an can i use any b series half shaft.. need help asap any help would be greatly appricated thankssss. o an i heard of if you get an oil relocater it will work?
Old 02-28-2012, 11:53 PM
  #279
da9 jdm717's Avatar
my h22 is an sh an i want to see a braket made with the h2b so if any1 has done this to a sh h22 can you take a pic of the braket i need made to make this work please help me out here asap cause thats the only thing holdin me up rite nowwwwww!!!!!!!!thanks in advance
Old 02-29-2012, 06:02 AM
  #280
I'm really 2slow
2fast4u831's Avatar
The only thing I've seen made is to weld 3 threaded pieces of aluminum to your block that bolt up to your mid shaft of course.
Old 04-16-2012, 12:43 PM
  #281
unusual71's Avatar
Originally Posted by Bserious
You use a B-series slave. In the OEM position the slave hangs out past the tranny on into the motor side. The reason something must be done here is to clear the larger H22 engine profile.
do you know how far out the H22 block pushes the slave cylinder? if its small I might just machine the block and run studs/nuts for the slave cylinder? Reason i ask is because im trying to do the h2b without buying a kit lol
My other question is in the kits, what is provided for the half shaft? is it just a bracket that holds the half shaft out further? closer? nevermind i found some pictures that showed the half shaft mounted up, will have to do some careful work once I get my stuff together.
Old 06-06-2012, 10:14 AM
  #282
shocker911's Avatar
Has anybody ordered the QSD kit in the last week or 2???? Im trying to buy a kit but when i go to there site and try to place my order i get this.
"This recipient is currently unable to receive money."
That makes me not want to order from them. After all the research i have been doing they have the kit that i would like to go with.
Old 06-06-2012, 10:19 AM
  #283
DA is best's Avatar
You have to call or email seth
916-792-1549
Gobigorgohome@quartersportsdrag.com
Old 06-06-2012, 10:38 AM
  #284
shocker911's Avatar
916-792-1549
thank you...i just e-mailed him
Old 09-24-2012, 10:50 PM
  #285
h2b_22's Avatar
i got a h22a with kazz lsd push 230hp on dyno now i wanna do a h2b do i have to re-dyno.
i will be putting b16 lsd tran
Old 09-24-2012, 10:55 PM
  #286
h2b_22's Avatar
it will only be the transmission change only
Old 02-10-2013, 09:43 AM
  #287
slobalt716's Avatar
noob question... im going f2b in my ek. can i use the stock f20b ecu to pass emissions? if not what other ecus can i use?
Old 02-18-2013, 04:44 PM
  #288
JDMJunky7's Avatar
Icon2 Re: H2B / F2B FAQ
Hey quick question, i just bought a used H2B kit out of a 96-00 EK hatch... will the mounts work in a 92 EG bubble?
Old 02-18-2013, 05:28 PM
  #289
jdmjohn1's Avatar
Depends on what kit you got. QSD you will need EG-DC driver side engine mount. Every thing else is the same. I would Highly recommend you to buy NEW flywheel bolts, but that just me!
Old 02-18-2013, 05:39 PM
  #290
JDMJunky7's Avatar
its an Evolution kit for a Ek9
Old 02-21-2013, 07:17 AM
  #291
neroazul's Avatar
The rear mount is different from EG to EK. The EG is a one-piece mount and the EK is a two-piece mount. You also will not use the driver and trans frame brackets.
Old 04-05-2013, 07:08 PM
  #292
kulo's Avatar
Want to buy
qsd ek kit and oil pan
Old 05-09-2013, 08:00 PM
  #293
sicc22's Avatar
Yes you can use the stock ECU to pass. Any honda with no engine codes and a working CAT will pass.... most of the time. You do know you can run any good dyno tuned ecu and pass as well. I wouldn't get a OEM ECU IMO check these guys out. http://www.phearable.net/
Old 05-11-2013, 04:04 PM
  #294
h2d_tim's Avatar
Both H2B kits include a custom timing belt mount on the engine that mates to the stock B-series chassis mount
can anyone confirm this.i been told it only works with their mounts.
Old 05-13-2013, 07:14 AM
  #295
kulo's Avatar
i need a good h2b header
Old 06-10-2013, 02:58 PM
  #296
ricertek's Avatar
anyone know where I can get h2b oil pan?
Old 06-24-2013, 05:16 PM
  #297
fknfastintegra's Avatar
You can use your stock oil pan. But if you have spare $$ to use. Qsd makes one
http://www.quartersportsdrag.com/Pan.html
Old 08-21-2013, 02:27 PM
  #298
xSOHC's Avatar
Where is there a good shop in the NJ/NY area that sells h2b kitts? Id imagine allbuilt might have some, vraveworks too but i havent seen any on their sites. Jw
Old 08-21-2013, 06:02 PM
  #299
nospaghetti's Avatar
Just order it straight from http://www.quartersportsdrag.com/
Old 08-21-2013, 06:36 PM
  #300
hybridmiklo's Avatar
I called them today. They told me to email them to use my debit card. I emailed them today but havent got a response yet. Hope they get back to me tomorrow. They said they are about a week and a half out for any kits right now
Quick Reply: H2B / F2B FAQ
