H22a (OBD1) w/auto swap into a 98 Accord
Old 03-04-2006, 10:52 AM
HandoEX's Avatar
Default H22a (OBD1) w/auto swap into a 98 Accord
I am looking for info about swapping an OBD1 H22A with an auto tranny (lsd) into my 98 Accord. I have not found much info about doing this swap but from what I know, this motor will drop into the factory mounts of a 6th gen accord. I've also read that that wiring for converting to OBD1 from OBD2 can be a bit tricky. Is this swap doable (not by me-by a shop) or should I scrap the idea of going with an OBD1 motor? I should state that I live in a state with no emphasis on emissions.
I have no experience with swapping motors so forgive my n00bness TIA for any help
Old 03-09-2006, 01:20 AM
91jdmhatchback's Avatar
Default Re: H22a (OBD1) w/auto swap into a 98 Accord (HandoEX)
This is Matt from fargo. I'll help you do the swap if you need it. I done 4-5 swaps, and 3 head swaps. It doesn't seem to hard everyone says it bolts up and the axles fit so the only problem is wiring. and i found a wiring harness that lets you use the obd-1 auto ecu instead of messing with the obd-2 imobilsor. just PM me if your interested. hope i helped
slvrCD7accord
03-11-2011 12:01 AM
CivicSpoon
04-27-2008 06:00 PM
HandoEX
05-09-2006 07:55 AM
Nextelbuddy
11-12-2003 01:56 PM
Quick Reply: H22a (OBD1) w/auto swap into a 98 Accord
