H22 distributor firing order
Old 04-11-2006, 01:46 PM
h22a_junkie's Avatar
Default H22 distributor firing order
Hey can someone tell me the distributor firing order for an h22 external coil distributor, say i am looking directly at the distributor what spark plug wire goes to what? i know upper right hand corner is number 1 cylinder but what are the other three? i have looked for a diagram and can't find one. I just bought a new distributor and the distributor is not labeled or anything
Old 04-11-2006, 02:38 PM
skunked's Avatar
Default Re: H22 distributor firing order (h22a_junkie)
1-3-4-2
Modified by skunked at 4:04 PM 4/11/2006
Old 04-11-2006, 02:49 PM
I just tried that and it won't even start
Old 04-11-2006, 02:54 PM
skunked's Avatar
Default Re: (h22a_junkie)
34
12
ok so your saying it should be like this
with the number one plug being the plug closest to the distributor?
Old 04-11-2006, 03:02 PM
92H22EG's Avatar
Ok, you got numero uno by the timing belt, number four is by the dizzy. Firing order is 1-3-4-2, so on the dizzy number one is top left, then going clockwise on the dizzy, number 3 is next then 4 then 2.
Old 04-11-2006, 03:03 PM
92H22EG's Avatar
Default Re: H22 distributor firing order (92H22EG)
cant really say top left, but kinda
Old 04-11-2006, 03:15 PM
ok when i run the wires like 34
12
it runs shitty buts runs, when i run the wires 13
24
it just back fires and never starts
Old 04-11-2006, 03:31 PM
skunked's Avatar
34
12
and number 4 cyl. is closest to the distributor.
Old 04-11-2006, 08:49 PM
2point2's Avatar
Default Re: (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">and number 4 cyl. is closest to the distributor.</TD></TR></TABLE>
jdmeg21
10-18-2009 04:18 PM
Neondog82
07-26-2005 02:00 PM
Boost3d22
06-22-2005 07:27 AM
SOHC_MShue
10-19-2003 01:54 PM
Quick Reply: H22 distributor firing order
