H22 92-95 civic axle ???
Old 01-27-2008, 08:01 AM
levee000's Avatar
Default H22 92-95 civic axle ???
ok i read about usin 90-93 accord intermidiate shaft and 90-93 teg axles
but i read i cant be lowered or the axles would bind
but how low can i be and the axles should go right in correct????
Old 01-27-2008, 10:02 AM
cliniCrx's Avatar
Default Re: H22 92-95 civic axle ??? (levee000)
Im not too sure on the how low you can go part. IMO if you're worried about you're car being too low and/or having axle problems, I would recommend you to get aftermarket axles such as hasport or something. I actually have a set of Hasport axles for an H22 into a civic for sale. PM me if you're interested.
Old 01-27-2008, 10:11 AM
ESP.net's Avatar
As always call the manufacture of the motor mount kit and ask for recommendation on the midshaft and axles.
We carry the ESP EG/DC H22A Motor Mount Kit
90-93 Accord midshaft is the better shaft to use F series, Dx or Lx will have it.
90-93 Acura Integra axles may work with the swap if they don't and they are too short your next option is 88-89 Acura Integra axles which are shorter then 90-93.
When you think you found an axle solution you will need to swap ONLY the passenger side inner joint for an Accord so that the clip meshes with the trans and clips in. Without the Accord 90+ joint your axle will slide in and out of turns.
Old 01-27-2008, 12:25 PM
levee000's Avatar
Default Re: H22 92-95 civic axle ??? (ESP.net)
ok welli have innovative mounts and if i use the accord mid shaft and 90-93 teg axles the axles should go right in without a prob correct if tney fit correct ????
Old 01-30-2008, 08:36 PM
erocksitr's Avatar
i had a two inch drop on my 92 hatch and had no prob with them
nathanjohnson2009
05-06-2010 05:59 PM
Ayeso
25
07-31-2008 09:54 PM
PotatoePAPA
03-31-2003 01:14 PM
luckyjun127
11-20-2002 10:55 AM
Zane
10-06-2002 04:27 PM
Quick Reply: H22 92-95 civic axle ???
