H SWAP NEED HELP
Old 03-20-2017, 09:16 AM
H Series Garage's Avatar
Default H SWAP NEED HELP
Im nearing completion on my h series civic swap and i have run into a problem.
My alternator isnt charging the battery, it will hold the voltage around 11.96V however it does slowly decrease and after about 15 minutes the car will die.
I got my alternator rebuilt and ran a straight wire from the alt to the battery but none helped.
Any help would be greatly appreciated. Thanks
Old 03-21-2017, 09:48 AM
Moderator
crazes's Avatar
Default Re: H SWAP NEED HELP
you might have a bad alternator. The charging voltage at the battery polls with the car running should be some where 13.7 to 14.5 if I am not mistaken.
Old 03-23-2017, 04:32 PM
e30bimmer89's Avatar
Yep, I'd say its a bad alternator.
Old 03-23-2017, 07:13 PM
Not the alternator! Got it rebuilt about 2 weeks ago.
FIXED #15 fuse under the dash blew. Replaced and it charges mint.
coltonboost
04-19-2015 03:30 PM
eggie75
03-25-2010 04:37 PM
d15vtecivic
06-11-2007 09:42 AM
biggdogg
04-25-2004 07:03 PM
EG6[B16A1]
06-28-2003 09:03 AM
Quick Reply: H SWAP NEED HELP
