can p28 unchipped run a h22a1
Old 03-21-2007, 05:59 PM
Hmotorsol's Avatar
Default can p28 unchipped run a h22a1
i was just wondering if a unchipped p28 can run an h22 in a del sol and what is the differences between the p28 and p13 are
thanks
Old 03-21-2007, 06:33 PM
high_revs's Avatar
yes...differences are fuel and timing maps (duhh) p13 looks for an egr and knock sensor...im sure there are a couple more
Old 03-22-2007, 10:06 AM
Relic1's Avatar
Default Re: can p28 unchipped run a h22a1 (Hmotorsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hmotorsol &raquo;</TD></TR><TR><TD CLASS="quote">i was just wondering if a unchipped p28 can run an h22 in a del sol and what is the differences between the p28 and p13 are
thanks</TD></TR></TABLE>
stock P28 on H22, technically yes. But if you push in any way you will have parts in no time. Plus start up will be a little funky. I wouldn't trust it to run the H22 for anything more than a start up check and maybe if you absolutely had to... a slow and easy on the throttle drive to a tuner.
Old 03-22-2007, 11:35 AM
Hmotorsol's Avatar
when i use the p28 it starts and idles alot better. while using the p13 it runs super rich and does not idle well and sputters. knock is not hooked, no egr and the secondary butterflys disconnected.
Old 03-22-2007, 12:31 PM
Relic1's Avatar
If you want to stick with the P28 you'll need either a single runner intake mani or an RPM activate switch and relay to open the IABs. (As well as chipping the P28 with H22 maps)
NOTE: the P13 will work also but your lack of EGR and knock will cause problems.
Old 03-22-2007, 02:17 PM
Hmotorsol's Avatar
ok going to chip the ecu i guess is there a place u would recommend for the chipping
i seen phearable.net and i know hondata is extremely good but kinda high. is there any other places i could look?
thanks for your help
Old 03-22-2007, 02:57 PM
Relic1's Avatar
it depends on what your plans are. tuning is always the best option if you're not going to run an OEM ECU.
If Hondata is a little out of your budget, check the tuner directory over at PGMFI.org. there are a lot of people on there that can chip your ECU and tune your car. Find a local person and go from there.
Old 03-22-2007, 03:53 PM
2point2's Avatar
Default Re: (Relic1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Relic1 &raquo;</TD></TR><TR><TD CLASS="quote">If Hondata is a little out of your budget, check the tuner directory over at PGMFI.org. there are a lot of people on there that can chip your ECU and tune your car. Find a local person and go from there. </TD></TR></TABLE>
best tip i've read in a while.
eg_h22
08-05-2007 10:21 AM
hondaguyef
04-15-2004 04:33 AM
Ransom
03-31-2004 11:02 AM
st0nedstoopid
11-05-2003 03:26 PM
prjctCIVIC
06-09-2002 02:57 PM
Quick Reply: can p28 unchipped run a h22a1
