Best way to remove passenger engine mount for K20a2 swap?? (92-95 Civic)
Old 03-07-2007, 05:50 AM
Fuster_Cluck's Avatar
Default Best way to remove passenger engine mount for K20a2 swap?? (92-95 Civic)
What is the best method to remove the mount? I don't want to hack up the sheetmetal when removing the mount. Some say use a titanium step drill bit, another says 23/64" drill bit, dewalt 3/8 drill bit with pilot tip, spot weld remover bit......
Anyone have any experience with this? What does a spot weld remover bit look like??
Thanks for any help
Old 03-07-2007, 12:22 PM
cpmike's Avatar
easiest way is to drill out the welds. and youll need a drill bit that can cut through metal, and is wide enough to break through the whole spot. theres no "right" tool because theres a million ways of doing it.
i just dont suggest a spot weld remover... its basically just the tip of a drill bit, but with more blades... they wear out quick and end up being pretty useless. ive removed mounts from bays before, i usually just use a titanium drill bit.
Old 03-07-2007, 07:32 PM
TrueZen's Avatar
Default Re: (cpmike)
I ended up using the stepped drill bit, and took it slowly until I drilled out most of the welds. Then it's up to using the crowbar to pry it off. If you're concerned about aesthetics then you can grind down what remains.
alwaysoverkill
Suspension & Brakes
15
03-28-2006 01:32 PM
tiresmoke
Audio / Security / Video
12-07-2005 02:59 AM
turtle-eg
10-11-2004 06:24 AM
Quick Reply: Best way to remove passenger engine mount for K20a2 swap?? (92-95 Civic)
