b18b w/gsr tranny-> ek coupe. what int. shaft/axles
Old 09-17-2004, 08:25 AM
blackeg's Avatar
Default b18b w/gsr tranny-> ek coupe. what int. shaft/axles
do i need a gsr intermediate shaft with this setup, or can u just use ls axles/int. shaft?
Old 09-17-2004, 08:30 AM
VTECVillain's Avatar
Default Re: b18b w/gsr tranny-> ek coupe. what int. shaft/axles (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg &raquo;</TD></TR><TR><TD CLASS="quote">do i need a gsr intermediate shaft with this setup, or can u just use ls axles/int. shaft?</TD></TR></TABLE>
94-01 USDM Integra's use the same intermediate shafts and axles, they are interchangeable with 94-97 Del Sol VTEC's and 99-00 Civic Si's. If you have 94+ LS shaft and axles they will work no problem. The 90-93 Integra shaft and axles will also work but you would need to change the driver's side tranny seal to a 90-93 seal.
Old 09-17-2004, 09:29 AM
blackeg's Avatar
Default Re: b18b w/gsr tranny-> ek coupe. what int. shaft/axles (VTECVillain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTECVillain &raquo;</TD></TR><TR><TD CLASS="quote">
94-01 USDM Integra's use the same intermediate shafts and axles, they are interchangeable with 94-97 Del Sol VTEC's and 99-00 Civic Si's. If you have 94+ LS shaft and axles they will work no problem. The 90-93 Integra shaft and axles will also work but you would need to change the driver's side tranny seal to a 90-93 seal.</TD></TR></TABLE>
ok. i needed the affirmation on this, cause i was reading an article on hybridgarage and the guy said he had a problem his int. shaft cause he was using a different tranny. now i just gotta rip the boots on my currently old axles and bring them to autozone to get new ones with lifetime warrantys
Old 04-23-2005, 08:32 AM
Fuster_Cluck's Avatar
Bump this up for the B18B I am picking up this upcoming week.
Must be non ABS axles though for direct plug-n-play, right?
I know GSR sxles worked with stock GSR swap in EG
EK with LS swap (stock) / axles should be good to go?
HondaCRZY
02-21-2015 05:43 AM
yellowbus
01-21-2008 07:11 PM
HamiltonRex
02-22-2006 03:58 AM
lillex
12-04-2003 04:17 AM
b18crx
05-26-2003 06:28 PM
Quick Reply: b18b w/gsr tranny-> ek coupe. what int. shaft/axles
