05 Civic Hybrid K20 Swap???
Old 03-08-2017, 07:56 PM
yueplee84's Avatar
Default 05 Civic Hybrid K20 Swap???
Hello HT, Just wondering has anybody ever done a k swap to a 2003-2005 Civic Hybrid???
Old 03-28-2017, 04:14 AM
dadozh22's Avatar
Default Re: 05 Civic Hybrid K20 Swap???
https://honda-tech.com/forums/honda-...4-fn2-3295467/
my build
so.. is a fd3
Old 03-29-2017, 01:40 AM
yueplee84's Avatar
Nice build, I'll be starting on mine this summer.
Old 02-27-2018, 12:25 AM
WaiZ444's Avatar
Hello HT. I will be start build Civic FD3 Hybrid to K series. @yueplee84 Are you done your swap ? Can you share if you done your car ?
Thanks.
Old 03-02-2018, 01:50 AM
Polygaryd's Avatar
im looking to swap a k20 or k24 into a 2003 civic hybrid frame also. i have just the car shell sitting around after using it as a parts car to fix another civic hybrid of the same year with much less miles. i hear the subframe from a civic si will fit right in there and since the engines are orientated the same way there is a lot less to do with cables and hoses not routed in stock locations. what i would like to know is what year civic si i need the subframe from and do they mean a civic si ep3 or is there a non hatch civic si of similar production years that the subframe will fit into the hybrid? also would i need the civic hybrid 5 sped shifter box or can i use the one from the ep3 or what?
sibiryak70rus
Honda Civic (2001 - 2005)
12-23-2015 09:11 PM
nolanwalter12
Honda Civic (2006 - 2015)
07-08-2014 06:03 AM
kaiba
Appearance Build Threads
02-11-2009 05:54 PM
docmccoy1
14
08-18-2007 10:57 PM
Quick Reply: 05 Civic Hybrid K20 Swap???
