[FAQ] 96-00 Auto to Manual Swap in full detail!! (44pics)
#277
Re: [FAQ] 96-00 Auto to Manual Swap in full detail!! (SOHC4life 96)
i have a 92 hatch that has a 5 speed i was wondering what i could use from that to convert my 98 coupe to a 5 speed
#278
Re: [FAQ] 96-00 Auto to Manual Swap in full detail!! (nastyboyz98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nastyboyz98civic »</TD></TR><TR><TD CLASS="quote">i have a 92 hatch that has a 5 speed i was wondering what i could use from that to convert my 98 coupe to a 5 speed</TD></TR></TABLE>
the tranny, shifter, slave cyl, clutch/flywheel, I think the linkage too.
#279
read the write up befor u ask questions like that
#280
Re: [FAQ] 96-00 Auto to Manual Swap in full detail!! (JDM_CRX_PLEASE)
in the write up he mentioned that you can use the auto pedal assembly with a clutch pedal added i understand that i would also need a brake pedal from a manual pedal assembly
is there any info on using the manual pedals on the auto assembly cause i will buy them from honda but i need to be sure that they will work and if there are any major mods i would love to know in advance
kthxbai
kthxbai
#286
i just did the swap and i didnt have any online info i saw that lil box that bolts into the slave mounts and i un pluged it to get it outta the way and i wasnt sure what it was i plug it back in and when i put my key in to start it it wouldnt turn over and i know it has something to do with the switch on the clutch petal how or what do i do and like you said it wouldnt let me take my key out so i tried to unplug the box and it made it possible to take the key out then but it still wont start please email me with what i need to do thanks for your time gostpd@yahoo.com
#287
Re: [FAQ] 96-00 Auto to Manual Swap in full detail!! (stpdfasthonda925)
stpfasthonda925 - Just follow the wiring instruction about the interlock system and the wiring system and youll be able to start your car.
#295
Seagull Management
Re: (tjthao752)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjthao752 »</TD></TR><TR><TD CLASS="quote">would this be almost the same way to do a auto to manual to a 94 integra?? j/w</TD></TR></TABLE>
Its more similar to a '92 - '95 civic auto to manual swap in that you have to deal with a pocket mount (either cut the old automatic version off the frame rail and weld on the automatic version, or buy a hasport mount that just bolts up like stock) otherwise its pretty similar.
#297
Seagull Management
Re: (tjthao752)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjthao752 »</TD></TR><TR><TD CLASS="quote">ah i see. so i should just buy the mounts from hasport mounts for a manaul then? then everything should be similar?</TD></TR></TABLE>
Yeah, more or less.
Yeah, more or less.
#298
Re: (94EG8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94EG8 »</TD></TR><TR><TD CLASS="quote">
Its more similar to a '92 - '95 civic auto to manual swap in that you have to deal with a pocket mount (either cut the old automatic version off the frame rail and weld on the automatic version, or buy a hasport mount that just bolts up like stock) otherwise its pretty similar.</TD></TR></TABLE>
Correct. I highly recommend the mount because its easier to work with. Other then that you could follow this thread.
#300
Re: [FAQ] 96-00 Auto to Manual Swap in full detail!! (Luserkid)
anyone in the houston area want to help me do this swap on my civic '00 dx 4 dr? I am dying here with out a clutch!!
