**Official H2B Discussion thread **
Old 10-21-2006, 06:19 PM
  #1251
lightcrx's Avatar
raise the limit to like 8200-8500, you dont really want to shift to 5th anyways exspecilly right before the line unless you had a 4.7 fd
Old 10-21-2006, 06:20 PM
  #1252
skunked's Avatar
Default Re: (JDMRice)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMRice &raquo;</TD></TR><TR><TD CLASS="quote">
that might be a problem then, I have to shift(into 5th) right before the 1/4 mile is up, thats with a 8000 redline..</TD></TR></TABLE>
spin it higher or run a larger diameter tire.
Better off hitting the rev limit in 4th before the traps then shifting to 5th
Old 10-21-2006, 06:41 PM
  #1253
hondaZvic's Avatar
Default Re: (lightcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">
honda doesnt sell ls parts j/k i had a ls tranny laying around ;P</TD></TR></TABLE>
doh!!
Old 10-21-2006, 06:44 PM
  #1254
JDMRice's Avatar
Default Re: (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
Better off hitting the rev limit in 4th before the traps then shifting to 5th </TD></TR></TABLE>
yeah thats what i though, when i hit the limitr I had a higher trap speed then if i had shifted.
Old 10-24-2006, 07:13 PM
  #1255
pubes2942's Avatar
If you guyz had to do it all over. what frank would you do?
Old 10-25-2006, 08:16 AM
  #1256
lightcrx's Avatar
i love pulling my motor out ;x out it goes again
Old 10-25-2006, 08:24 AM
  #1257
DC4_MADMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">i love pulling my motor out ;x out it goes again</TD></TR></TABLE>
What happened now?
Old 10-25-2006, 08:47 AM
  #1258
Whorehey Nighten's Avatar
your a maniac what happ'd??
Old 10-25-2006, 08:57 AM
  #1259
lightcrx's Avatar
when i put the second gear in the tranny i only changed the counter shaft gear not the input shaft gear too... but the good thing if the tranny shifts smooth but 2nd wines lol, ill pull it today and fix it and try to put it back aswell ;] fun fun.. the engine runs like a top notch tho
Old 10-26-2006, 04:52 PM
  #1260
Colt Seavers's Avatar
Which block has the 97mm crank with the 55mm mains?
Old 10-26-2006, 05:17 PM
  #1261
I'm really 2slow
2fast4u831's Avatar
Default Re: (Colt Seavers)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Colt Seavers &raquo;</TD></TR><TR><TD CLASS="quote">Which block has the 97mm crank with the 55mm mains?</TD></TR></TABLE>f23. found in 98+ accords
Old 10-26-2006, 05:44 PM
  #1262
lightcrx's Avatar
my car = working turns out you gotta use the ls imput shaft when you change 2nd gear(ls)
haha wish i would have known that sooner
Old 10-26-2006, 10:03 PM
  #1263
STEV3-O's Avatar
anyone from cali going to CMI?
Old 10-27-2006, 08:13 AM
  #1264
lightcrx's Avatar
ill probley be there... and maybe chris
Old 10-27-2006, 01:53 PM
  #1265
WHITE DEATH's Avatar
When you do the 1/2 inch over mod does the crank pulley slide right up against the lower timing gear? If so what keeps the t-belt from sliding off?
Old 10-27-2006, 01:55 PM
  #1266
skunked's Avatar
Default Re: (jdmtegra666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmtegra666 &raquo;</TD></TR><TR><TD CLASS="quote">When you do the 1/2 inch over mod does the crank pulley slide right up against the lower timing gear? If so what keeps the t-belt from sliding off?</TD></TR></TABLE>
only do this on a track application (if that). You can't run a t-belt cover if you do this and you should use a t-belt washer to keep the belt from walking.
Old 10-27-2006, 02:42 PM
  #1267
only do this on a track application (if that). You can't run a t-belt cover if you do this and you should use a t-belt washer to keep the belt from walking.</TD></TR></TABLE>
YEAH....You can use the B-series washer and slightly modify it.......you'll see how it need to be modified
Old 10-27-2006, 03:39 PM
  #1268
lightcrx's Avatar
better off using a f22 washer, its the same size as the crank you just gotta cut the keyway out
Old 10-27-2006, 06:33 PM
  #1269
Default Re: (9WON4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9WON4 &raquo;</TD></TR><TR><TD CLASS="quote">
YEAH....You can use the B-series washer and slightly modify it.......you'll see how it need to be modified</TD></TR></TABLE>
Thats what I did. Now the pulley is hitting the tensioner for the balance shaft. I will just get a washer to space it I guess.
Old 10-27-2006, 09:36 PM
  #1270
lightcrx's Avatar
take that off make a spacer ;]
i got my cf hood on ;x i wish i would have got the sir style then i could lower it alot more. i had this cf hood for a while(2 yrs) this **** is soooooo hiiiggghhhhh ill take pics tomarrow
Old 10-28-2006, 09:45 AM
  #1271
DeuceD's Avatar
yea pics please
Old 10-28-2006, 12:33 PM
  #1272
lightcrx's Avatar
are you going to cmi randy? ill be there
Old 10-28-2006, 02:22 PM
  #1273
high_revs's Avatar
Default Re: (9WON4)
i used an h series washer, but had to cut a slot into it to slide over the guide worked well
Old 10-28-2006, 04:16 PM
  #1274
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lightcrx &raquo;</TD></TR><TR><TD CLASS="quote">take that off make a spacer ;]
speaking of......you ever finish that T-belt cover template
Old 10-29-2006, 07:29 AM
  #1275
lightcrx's Avatar
never started it ;x been busy ..... ill still do it if your interested
Quick Reply: **Official H2B Discussion thread **
