Push Start Bulb
Push Start Bulb
Does anyone know the size/number of the bulb for the push start button? I want to replace it with a LED because the OEM bulb sucks...
Thanks.
Thanks.
1 Post
Re: Push Start Bulb
Re: Push Start Bulb
It's #6 in the link below (14V 0.56W)
http://www.hondaautomotiveparts.com/...atcgry5=SWITCH
Re: Push Start Bulb
If you're trying to replace it with a LED or bulb with different color, best bet is to remove it, measure the base and match it up.
Re: Push Start Bulb
they don't make them
The smallest they make is led T3
and the one is smaller still
I know I have LEd's and thought of swapping the led bulb into the old housing but the led is too big to fit into the hole
Also, my car has leds in other areas and if you could get one in there it would be weaker because an led lights only the direction it faces
shit post warrior
Re: Push Start Bulb
My 02's push start bulb lit up but has since gone out. It's normal.
Sucks all the work just to replace it and most owners don't worry about it.
Re: Push Start Bulb
I can't even seem to find the size. It may be a simple component led which I sell that you remove the old bulb and solder this one in its place. Email me at lightsonleds@gmail.com if you're interested. I'm an HT sponsor
Re: Push Start Bulb
Mine was out when I bought the car. I had plans on replacing it but after finding out it's nearly impossible I just deal with it.
