Honda S2000 Honda S2000
maintainence on a 91-94 NSX
Old 07-27-2002, 01:05 PM
R-gonaut's Avatar
Default maintainence on a 91-94 NSX
Im thinking about getting a used NSX, several I have found for great prices. I will of course have them checked out, but I want to know what to expect for general maintainence costs on a daily driven, older NSX.
It'll prolly need tires and timing belt, but generall speaking, are NSXs costly to maintain?
How much do you usually spend on oil changes(oil + filter) if you do it yourself?
What kinda gas mileage can I expect from an older one?
I will definetly try to find one in the best conidtion, but its expected that a car of this age will need some type of work.
[Modified by gsrmunj, 2:07 PM 7/27/2002]
Old 07-27-2002, 02:15 PM
Painting Masterpieces
Ponyboy's Avatar
Default Re: maintainence on a 91-94 NSX (gsrmunj)
There's a special section on http://www.nsxprime.com in the FAQ. Every answer you ever wanted to know about the NSX is probably there.
Old 07-27-2002, 05:02 PM
H-T Order of Merit
nsxtasy's Avatar
Ponyboy mentioned the NSX FAQ, which is the best place to start. The table of contents page is here. Under the "Maintenance" heading, you'll find sections containing the schedule and typical costs.
You're right about the timing belt and water pump replacement, which costs around $1200, parts and labor. It's specified for every 90K miles or 6 years, whichever comes first. Many early NSX which haven't hit 90K miles are overdue for this service.
Tires. The OEM tires (Yokohama A022H or Bridgestone RE010) were designed for the NSX and are terrific for handling. They cost around $200 each. Rear tires generally last 5-8K miles, which you can increase slightly by taking some of the toe out of the alignment. Front tires last about twice that long.
Other than that, most of the schedule is similar to that of other Hondas, with costs of parts only slightly higher.
Clutch replacements can be expensive, though. The OEM clutch typically lasts 30-50K miles (some much more than that though). A replacement runs about $2200, parts and labor, for the '91-96; the '97+ is more expensive.
5.2 quarts. I like synthetic, which runs around $4.50 a quart. The Honda filter lists for $14 and you can buy at a discount for around $11.
Same as a newer one. EPA ratings are 19 city, 24 highway, and that's about what I generally get. I've gotten 28-29 on a long trip. And 9-11 mpg on the track.
type B16
Acura NSX
140
02-03-2007 07:01 AM
Cookie_Monster
Acura NSX
03-03-2005 09:40 AM
Ponyboy
Acura NSX
10-14-2004 12:45 PM
REVS29K
Honda S2000
08-23-2002 09:26 AM
BlueShadow
Honda S2000
11
01-23-2002 03:11 PM
Quick Reply: maintainence on a 91-94 NSX
