i need main bolts torque specs for F20C
Re: i need main bolts torque specs for F20C (Zigga)
Get a shop manual. It has EVERY torque spec. I do not have mine in front of me. If you don't have them by tonight, I will look it up for you.
Re: i need main bolts torque specs for F20C (doublej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublej »</TD></TR><TR><TD CLASS="quote">pm me a fax number and I will copy the page out of my shop manual.
Jim</TD></TR></TABLE>
WTF? just give him the number(s) ... y go all that hastle if you can give it to him right MEOW .....
Re: i need main bolts torque specs for F20C (Y2K_S2K)
if it is the head bolts you are on about then it is 22lbf/ft then if useing the old bolts you turn each bolt by another 90 degrees twice but if new bolts then turn each bolt 90 degrees 3 times.
New User
Re: i need main bolts torque specs for F20C (edd001)
Torque spec for the lower block to the upper block is as follows... 22lb/ft in sequence (from the centre out) then an additional sixty degrees (get a proper torque angle gauge for this...)
Then tighten the 8mm bolts in sequence (also from the centre out) to 16lb/ft
I assume this is what you mean by main... Main bearings...
Archidictus
11-26-2004 03:15 PM
