Honda S2000 Honda S2000
Gas Mileage
Old 02-13-2005, 11:20 PM
Mr. Lucky's Avatar
Default Gas Mileage
How many miles on a full tank are you guys getting?
i've got 1/2 a tank left with 140 miles on the trip odo.
Old 02-14-2005, 04:49 AM
Atheist's Avatar
https://honda-tech.com/zerothread?id=985978
searched.
Old 02-14-2005, 08:25 AM
Mr. Lucky's Avatar
Default Re: (Atheist)
thanks man, i guess i forgot to select archive when i searched for it
for the help.
Old 02-14-2005, 08:26 AM
papa5murf's Avatar
Default Re: (bs-inc.s2k)
that sounds about right.... but it seeems like you're babying the car hahahahaa..
Old 02-14-2005, 08:34 AM
Francesco's Avatar
Default Re: (03s2kblue)
i get usually 240 miles to a tank
Old 02-14-2005, 10:28 AM
SlowWhiteEvo's Avatar
Default Re: (Francesco)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Francesco &raquo;</TD></TR><TR><TD CLASS="quote">i get usually 240 miles to a tank</TD></TR></TABLE>
same here
Old 02-14-2005, 11:47 AM
Nishant's Avatar
Default Re: (SlowWhiteS2K)
i get 250-260 with shell 93 gas
then 240-250 with sunuco 94
Old 02-14-2005, 12:11 PM
revhi's Avatar
170 with 2 bars left, and filled a little over 10 gallons.
Old 02-14-2005, 12:12 PM
Francesco's Avatar
Default Re: (revhi)
whats everyones driving style though?
i say im 50/50 with the vtec thing and high reving.
Old 02-14-2005, 12:20 PM
Nishant's Avatar
i'm 40/60 more towards keeping it under 5k rpms
Old 02-14-2005, 12:30 PM
revhi's Avatar
Mine dosent matter, city/highway. All the same never over 200 a tank.
Old 02-14-2005, 12:32 PM
Nishant's Avatar
Default Re: (revhi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhi &raquo;</TD></TR><TR><TD CLASS="quote">Mine dosent matter, city/highway. All the same never over 200 a tank.</TD></TR></TABLE>
that bad from SC?
Old 02-14-2005, 12:51 PM
Francesco's Avatar
Default Re: (revhi)
your gears affect the gas milage more than the SC
Old 02-14-2005, 01:02 PM
2000S2000Mike's Avatar
Default Re: Gas Mileage (bs-inc.s2k)
It obviously varies. I've gotten 31 mpg on the road, but the last time it hit 1/2 a tank, I hadn't 100 on my trip odometer! But take into consideration that later that day the warning light on the gas gauge came on, I only could put in 10.1 gallons!
Old 02-14-2005, 01:07 PM
Nishant's Avatar
Default Re: Gas Mileage (2000S2000Mike)
jackson only has 4.44 gears, i have 4.77 and i am pulling better mileage
Old 02-14-2005, 01:34 PM
Francesco's Avatar
Default Re: Gas Mileage (Nishant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant &raquo;</TD></TR><TR><TD CLASS="quote">jackson only has 4.44 gears, i have 4.77 and i am pulling better mileage</TD></TR></TABLE>
you like the 4.77's?
im want the 4.44's, but im trying to gather opinions about everything.
Old 02-14-2005, 02:20 PM
Mr. Lucky's Avatar
Default Re: Gas Mileage (Francesco)
i finally got to enjoy my car today. got cloudy warm weather about 60 degrees. i had the top down and was just coasting on the highway to the mall. i decided to just push it, to see how what this baby can do. When i looked down i was already at 105 ... so i decided to slow down. i had a half tank at the start of the day now i'm down to a 1/4 .... at least i enjoyed it, i think i'm going to try shell's gas to see if i can get better mpg
Old 02-14-2005, 03:13 PM
Nishant's Avatar
im want the 4.44's, but im trying to gather opinions about everything.</TD></TR></TABLE>
if you plan on supercharging, no 4.77's. its overkill. if you're going NA, 4.77 is fine
Old 02-14-2005, 07:04 PM
Project SSAP1's Avatar
depending on how i drive i get between 200-260
highway driving of course gets you better gas milage then stop & go traffic...stayin in high rpm's doesnt help either
also...the gas gauge sucks!!!!!!!!!!!!!!! i can ride on empty for a long time...sometimes the gas gauge gets 2 more bars when on E....and when i fill up the max i have ever gotten is 11.8 gallons...is this normal??
Old 02-14-2005, 08:40 PM
Nishant's Avatar
Default Re: Gas Mileage (Project SSAP1)
we have a 13.2 gallon tank. our "reserve" is 3 gallons so your fuel light comes on when you have 3 gallons left (roughly). its somewhere in the manual. i tested this out by driving 45 miles with no bars and wound up filling up 12.6 gallons
i don't recommend doing this but going 20 miles or so after your fuel light comes on is no biggie, i do this all the time
Old 02-14-2005, 08:55 PM
shit post warrior
ITRbroham's Avatar
Before I was getting almost exactly 200-210 mpg doing mostly city driving. Now before you guys go WTF?, I most definitely have a "lead" left foot and I rev-match alot. This really does alot to screw up my gas mileage.
The most miles I have driven on a tank of gas was 320 miles. It was mostly highway driving and not much city driving. Ever since I started driving I've always been under the impression that it wasn't a good idea to drive with the fuel pickup sucking gas from the bottom of the tank. So when the light comes on with two bars left I will go fill up.
Old 02-19-2005, 03:34 PM
evil vapor's Avatar
your gears affect the gas milage more than the SC</TD></TR></TABLE>
wrong! your right foot affects gas mileage.
A shorter final drive, SC and turbo will actually improve gas mileage at partial throttle (ie freeway cruising).
However, when making more power from a turbo or SC, you'll burn more fuel at WOT when compared to a stock setup running shorter gears. Make more power, burn more fuel.
Old 02-19-2005, 11:20 PM
revhi's Avatar
Default Re: (vapor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vapor &raquo;</TD></TR><TR><TD CLASS="quote">wrong! your right foot affects gas mileage.
i
How so? With gears even at partial throttle cruising, your in a higher rpm range than stock, using more gas. My freeway gas mileage is the same as my city. When I went to Pittsburg with everyone, I had to stop one more tme for gas than everyone else. Even John driving real slow had to stop an extra time because of his gears and s/c. Nishant you remember, you left the slow group for ours. lol
Old 02-20-2005, 03:52 PM
Nishant's Avatar
Default Re: (revhi)
How so? With gears even at partial throttle cruising, your in a higher rpm range than stock, using more gas. My freeway gas mileage is the same as my city. When I went to Pittsburg with everyone, I had to stop one more tme for gas than everyone else. Even John driving real slow had to stop an extra time because of his gears and s/c. Nishant you remember, you left the slow group for ours. lol </TD></TR></TABLE>
i had no gas problems. i am getting 27-28 mpg on the highway instead of 30-31. but overall with my daily driving, i am actually getting better mileage with my gears. i used to avg about 20-22. now i am at 22-24mpg with the 4.77
Old 02-20-2005, 05:05 PM
revhi's Avatar
I your yellow box set right? I found mines still off a bit and I cant get it perfect.
Quick Reply: Gas Mileage
