Honda S2000 Honda S2000
CEL P1457
Old 08-30-2011, 09:43 AM
xandreaviolette's Avatar
Icon3 CEL P1457
Hey Guys,
I bought a honda S2000 a week ago. Its an 03 and has 100,000 miles on it. The CEL just came on and is reading a code of P1457. I know it's an emissions code for the control canister system. Have any of you had this code?? If so, what fixed it and is it something I can do myself?
Old 08-31-2011, 04:28 AM
hatrickstu's Avatar
Default Re: CEL P1457
mine is on right now for this. may crawl under the car this weekend and poke around.
Old 08-31-2011, 07:06 AM
techtalk's Avatar
The most common cause for this DTC in climates that have snow is a rusted/corroded EVAP bypass solenoid.
If you don't live in a climate that subjects your S2000 to such adverse weather conditions then the code has something to do with the EVAP canister. The EVAP cannister is located near the rear left wheel. If you look from behind towards the left half shaft, you'll see a black box with a "honeycomb" pattern on the end of it. That's the EVAP can. On that thing, is a purge valve (ref #5 in this S2000 diagram). You may have a bad purge valve or a bad wiring harness or one of hoses going or coming from the cannister is damaged or fallen off. The cannister itself may be cracked. This part belongs to a fuel recovery system the pulls fuel vapours out of the system and puts it back into liquid form so it doesn't go into the atmosphere.
CEL P1456 usually denotes a loose or bad gas cap but it doesn't hurt to double-check your gas cap to ensure that it's screwed on properly.
Good luck guys!
Old 08-31-2011, 07:13 AM
Thanks!! We replaced the gas cap last night then reset the light. We've been about 30 miles since then and it's not back on yet. Hopefully that took care of it. If not, we'll def take your advice TechTalk and check everything else out!
Old 08-31-2011, 08:27 AM
hatrickstu's Avatar
gas cap will not take care of it
Old 09-04-2011, 08:06 AM
Boosted Stu's Avatar
Thanks I have the same problem
Old 09-05-2011, 07:36 AM
We've been 260 miles since we replaced the gap cap and reset the CEL. the CEL hasn't come on yet...hopefully thats all it was.
Sean @ ESG
Honda S2000
10-22-2011 06:15 AM
Bunger
09-12-2011 09:00 AM
gooberwolf
06-20-2005 11:57 AM
Pfieff
07-28-2003 04:19 PM
Quick Reply: CEL P1457
