Honda S2000 Honda S2000
6-point harness install
Old 05-14-2009, 04:23 PM
rice4life's Avatar
Default 6-point harness install
more pics here - > http://gotspeed.110mb.com/2001_s2000_harness.php
Old 05-14-2009, 05:30 PM
Black S2K's Avatar
Default Re: 6-point harness install
nice bar hardog?
Old 05-14-2009, 05:46 PM
rice4life's Avatar
Originally Posted by Black S2K
nice bar hardog?
yeap, Hard Dog. http://gotspeed.110mb.com/2001_s2000_rollbar.php
Old 05-27-2009, 03:00 PM
New User
SlipStreamGSR's Avatar
are those BRIDE's comfortable, thinkin about getting some for my GSR
Old 05-27-2009, 04:52 PM
bky
bky's Avatar
Curious: why didn't you use fender washers on the back tie bar? It looks like one nut is already partially through the hole.
Old 05-27-2009, 07:58 PM
rice4life's Avatar
this are fake Brides from ebay. they are more comfortable than full buckets because they can recline. but like any bucket, they are a pain to get in and out but you get used to it.
Old 05-27-2009, 08:02 PM
rice4life's Avatar
the first nut is basically a spacer, the thread are drilled through and i grind it down at an angle to provide a flat surface for the second nut to seat on. i was planning on welding the spacer to the back plate.
here are some pics of the additional brace from the back plate to the roll bar plate, and the spacer welded on.
Old 05-27-2009, 08:19 PM
Honda-Tech Order of Merit
Chris.'s Avatar
i thought that there was a harness bar on the hard dog bar, or did you happen to buy one without the harness bar?
btw great install pics. i want a hard dog bar so bad... but i want to try and retain using the stock plastics (modified with removed roll hoops) if its possible
Old 05-27-2009, 08:22 PM
bky
bky's Avatar
Gotcha: I see the bevel on the nut now. Unusual.
That brace makes it look a lot safer. Does it get in the way of the spare tire on the other side?
Old 05-28-2009, 02:32 AM
rice4life's Avatar
the bolt goes through at an angle because the front plate is not parallel to the rear plate. the brace does not interfere with anything but you wont be able to mount the stock roll hoops.
Old 05-28-2009, 05:27 PM
bky
bky's Avatar
Stock hoops are kinda redundant at that point anyway.
Type X
Honda Civic (2006 - 2015)
38
02-07-2010 08:59 AM
EvasiveMotorsports.com
27
08-01-2006 04:05 PM
alpha
12-23-2004 11:07 AM
georgiajdm
03-15-2004 12:46 PM
b00st-0wnz
12-06-2001 12:19 AM
Quick Reply: 6-point harness install
