wiring H22 question
wiring H22 question
I did this a h22 swap on my cb7 and I am readdy to do the wiring.
So on sensors like the vtec oil pressure sensor the sensor has 2 wires on its plug. Do i just ground one and run the other wire to the Ecu?
Re: wiring H22 question
Ah the P0F ECU. I'm not familiar with it, so I'm not sure if it uses the ECU as the VTM ground or the VTM signal (+Voltage). IIRC the USDM and JDM are opposite to each other. Not sure which one the P0F is modelled after.
usdmftw
07-04-2011 11:25 AM
cccya
04-07-2002 07:56 PM
