What do the H22a Fidanza flywheel marks mean?
Old 11-27-2009, 01:01 PM
butter99's Avatar
Default What do the H22a Fidanza flywheel marks mean?
I have an H22a with fidanza flywheel. The flywheel has two notches ..one is for TDC and the other is for 15 degrees BTDC.
which notch is which?!
is the bottom notch the top notch the TDC or the bottom?
I need to know so I can time the engine using the sight hole to 15 degree BTDC.
please honda guys help (:
Old 11-28-2009, 04:32 PM
butter99's Avatar
Default Re: What do the H22a Fidanza flywheel marks mean?
BUMP please
2 notches on the flywheel. What do they mean?
Old 11-28-2009, 05:22 PM
butter99's Avatar
bump
Old 11-28-2009, 06:38 PM
butter99's Avatar
bump
Old 11-28-2009, 07:06 PM
speedracer9k's Avatar
set your cam and crank at tdc and see which mark lines up...that'll tell you which one is the tdc mark
Old 11-28-2009, 07:13 PM
butter99's Avatar
You are a freakin genius! DUH ~ Thank you
Old 11-29-2009, 07:55 PM
TheJGB3's Avatar
I agree, I believe the flywheel only mounts on the crank one way.
Old 11-29-2009, 09:33 PM
218luder's Avatar
yup i believe its tdc and 15 degrees if i remember right, but correct me if im wrong
Preludes'R'Us
11-12-2005 10:56 AM
anomale
10-13-2005 07:00 PM
jdmboy
09-04-2005 07:04 PM
H_doubledeuce_A1
03-30-2004 10:05 AM
jdmcivicferio
12-01-2002 02:01 PM
Quick Reply: What do the H22a Fidanza flywheel marks mean?
