Vacuum vs Electric controlled EGR valve
Old 08-10-2006, 12:15 AM
cidery's Avatar
Default Vacuum vs Electric controlled EGR valve
Hi,
Typically your EGR valve is controlled by a vacuum hose running to your intake manifold through a control solenoid. With this system you have 3 wires running to your EGR valve (valve lift sensor) and 2 wires running to a separate control solenoid.
Some newer (if not all or most them ?) engines come with electric controlled EGR valve, which has a plug with 5-wires.
Now the question is: are these two EGR systems interchangable?
Can I replace the vacuum controlled EGR valve with electric controlled EGR valve just by re-arranging these 5-wires (and plugging the vacuum hose connection in the intake manifold) ?
thank you for any replies!!!
-t
Old 08-10-2006, 06:22 AM
RTFM
v4lu3s's Avatar
i highly doubt they are interchagneable. you can always try, but i suspect the solenoid that controls vacuum is actuated differently than the electronic control as fr as whether is straight off or on or a potentiometer.
Old 08-10-2006, 07:06 AM
jetlude's Avatar
Default Re: (v4lu3s)
They are not interchangeable
RoscoeT
07-25-2015 09:12 PM
Happy Gilmore
11-07-2008 08:15 AM
wadsworth
05-12-2008 09:24 AM
1999gs-r
10-20-2004 06:25 AM
chromedome
03-30-2002 09:30 PM
Quick Reply: Vacuum vs Electric controlled EGR valve
