torque help
space cadet
Re: torque help (HOLDEM1981)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HOLDEM1981 »</TD></TR><TR><TD CLASS="quote">hey guys,
I need to know the torque specs for stock h22 rods, main, and head bolts. I'm reasembling the bottom end of a stock h22.
helm manual page 7-25
install the rod caps and bearings, and torque the nuts to 34 lb ft.
helm manual page 6-43
tighten cylinder head bolts sequentially in three steps.
29 lb ft
51 lb ft
72.3 lb ft
helm manual page 7-26
check rod bearing clearance with plastigauge then torque the capnuts to 34 lb ft
install main bearing caps and bearing cup bridge.
check clearance with plastigaug, then tighten bearing cap bolts in two steps. int eh first step tighten all bolts in sequence to 22 lb ft. in the final step tighten them in the same sequence to 54 lb ft.
Hope thats what you needed.
to rebuilding without a helm manual
29 lb ft
51 lb ft
72.3 lb ft
Re: torque help (Shakes)
Thanks man.
I bought this motor for the crank, my engine is sleeved with new rods pistons, etc. I only needed to assemble this motor with the old crank because a friend wants to put it in a del sol. Thanks for your help.
piggypen
07-04-2005 05:07 PM
