Removing Shift Cables
Old 02-21-2011, 04:59 PM
Don Jefe's Avatar
Default Removing Shift Cables
So I'm trying to remove the shift cables from my part-out car but I am perplexed as to how you remove them. I have the base of the shifter (yellow plastic piece under center console) unbolted, the cable mount that fastens to the tranny is unbolted and the bracket underneath the car near the steering rack has been unbolted as well.
The cables are free, I can move them around, but the hole where the cables feed into the interior is too small to let the bracket through and I can't figure out a way to remove the cables from the base of the shifter itself. At this point I'm ready to grab the dremel
Anyone have any thoughts or experience?
Old 02-21-2011, 05:13 PM
2point2's Avatar
Default Re: Removing Shift Cables
Did you pry off the clips that look like this? ^^^^
If not, just use a flathead, give it a twist, and they should break free.
Old 02-22-2011, 10:35 AM
Don Jefe's Avatar
Are these clips on the bracket end or the shifter end?
Old 02-22-2011, 01:04 PM
Hawkze_2.3's Avatar
They hold the cables to the shifter base.
Old 02-23-2011, 06:37 AM
2point2's Avatar
They are on both ends.
Old 02-23-2011, 06:59 AM
warning92lude's Avatar
yes there on both ends and theres like two ten mil bolts underneth the car under the shifter
Old 02-24-2011, 05:18 PM
Don Jefe's Avatar
Okay, perfect, I know exactly where these are now. When I first saw them they looked welded, but apparently are removable. Problemo solved, thanks for the help guys.
Mr.EM1
01-06-2022 09:49 AM
EJeff8
22
01-04-2011 05:15 PM
I Am White
03-14-2007 05:47 AM
TheAccordGuy
10-10-2006 07:09 AM
92CIVICCX
01-20-2003 11:10 AM
Quick Reply: Removing Shift Cables
