Prelude not shifting into gear
Old 11-16-2015, 05:47 PM
Rookie90's Avatar
Default Prelude not shifting into gear
I have a 96 Honda Prelude with a manual transmission. My prelude won't shift into gear from neutral. Changed the transmission fluid, checked the clutch fluid resevoir and filled it up and bleed out the air. I can shift the gears when the car is off. Checked the slave cylinder and it moves when I press on the clutch. Not sure what else it could be. Is it the Clutch itself?
Old 11-17-2015, 08:35 AM
StreetShotz's Avatar
Default Re: Prelude not shifting into gear
If the tabs on the pressure plate are broken it will cause this. IF you are 100% sure your hydraulic system is working and yet it will not go into gear the clutch is the next thing to check. If you can, take a look down the access port on the trans casing and you can take a look.
Old 11-17-2015, 06:27 PM
backinblue92's Avatar
Well, cant be a broken clutch fork. Or bearing. So yeah, gotta be the fingers on the pressure plate are worn bad.
When the car is idling, and u put a little bit of pressure on the clutch, does it vibrate pretty good?
Old 11-18-2015, 01:54 PM
Moderator
crazes's Avatar
also double check to see if your carpet underneath the master cylinder is leaking! It can start leaking and you would never know.
Old 11-19-2015, 01:21 PM
And to the OP
The "clutch itself" is just a friction disc. Sandwiched between a smooth flywheel and a pressure plate, with fingers inside that a slave cylinder-actuated bearing presses into to force release the disc, flywheel and plate.
I'd say u need to tear it apart and check it out. 4 hours one way for a first-timer. Not difficult. Just have to take ur time and be careful.
Old 08-12-2020, 02:15 PM
Sabrina Birge's Avatar
Have a 2000 honda prelude we're purchasing with new clutch and all the corresponding cylinders. It now no longer goes into gear. Assuming the person bled lines correctly what other possibilities could be wrong?
Old 10-09-2020, 10:14 PM
AndyD's Avatar
Does it go into gear when the car is off?
If it goes into gear when the car is not running, it could be the clutch disk is warped or the pressure plate wasn't torqued down properly during installation, or a bolt backed out.
Old 10-10-2020, 08:56 PM
JRCivic1's Avatar
Not only should the installation be considered suspect, a "New Clutch" is sometimes code for "got the cheapest crap I could find on E-Bay so I could sell the car" and the parts could be junk. Test as AndyD stated above... if it goes into gear easily when the engine is NOT running, but will not go into gear when the engine IS running, and assuming that you have witnessed the clutch release arm move at least a half inch in and out when the clutch pedal is depressed to the floor and then fully released... then you have a clutch/flywheel/release bearing related issue and the transmission will have to be removed to see what's happening.
exgen01
04-15-2023 03:38 PM
dansaleen_04
10-21-2010 01:21 PM
jwshilli
07-14-2009 03:02 PM
Tutin77
10-04-2005 01:14 AM
4thgenlude
10-05-2004 09:30 PM
Quick Reply: Prelude not shifting into gear
