oil change question
oil change question
i did an oil change today
im guessing the oil hasnt been changed since the swap
after how many miles is your engine used to bad oil running through it?
Re: oil change question
your engine doesn't get used to it.. what do u mean by bad oil? if you mean non-synthetic oils, by no means are they "bad" as long as they are the correct weights the oil should still do its job.
improper lubrication = friction = heat = problem
Alright thanks i just meant old oil and i read up somewhere your engine can get a leak from new oil if its used to old oil
i put 5w-30 in it today so it should be good
thanks
craig
thanks
craig
1 Post
Some people say that synthetic can cause seals to leak if you switch over from using dino oil for a long time, but that is just here-say for the most part. Leaking has nothing to do with how old the oil is...the older the oil is the worse it is on your engine.
tensai717
12-09-2001 03:49 PM
