Lower Ball Joint NUT removal and installation
Old 07-27-2010, 06:22 AM
oranginal's Avatar
Default Lower Ball Joint NUT removal and installation
I removed the passenger side axle after getting a ball joint separator.
Now when i put it all back together and try to get the nut on the threads of the lower ball joint it just spins the ball joint. I didn't press the balljoint out of it's arm/bracket, just from the Lower Control Arm.
Is there a way to stop the ball joint from spinning so i can get the nut back on.
Thanks
Old 07-27-2010, 12:55 PM
oranginal's Avatar
Default Re: Lower Ball Joint NUT removal and installation
tried the jack method but no luck....other ideas?
not sure what the "propper procedure" is....if there is one.
Old 07-27-2010, 01:25 PM
b16racereg6's Avatar
do the same thing with the jack and have some one stand or push down on the rotor/ hub and it normaly dose the trick unless u have an impact gun to zip it on. G/L
Old 07-27-2010, 04:27 PM
oranginal's Avatar
tried an impact gun with no luck with one jack.
will have to see if i can get someone to stand on the rotor.
any other suggestions or ideas just in case that doesn't work?
Old 07-27-2010, 04:32 PM
wannaBjdmca6's Avatar
i had the same problem and my dad told me to put a wrench (circle side) in between the ball joint and the nut, then tighten it then loosen it and repeat until you can slide the whole nut all the way.
-p-O <------ball joint, wrench (as a spacer), then castle nut then tighten.
it worked!
of course you will take out the wrench wen you're ready to toque all the way
Old 07-27-2010, 05:06 PM
oranginal's Avatar
Please explain more....very confused by your wording but would like to understand
Thanks,
steve
Old 07-27-2010, 08:39 PM
InvaderTrax's Avatar
Now, with the ball joint completely exposed, can you turn the ball inside the socket easily? Does it have any up and down movement? Sounds like your ball joint may simply be worn out
Old 07-28-2010, 05:53 AM
oranginal's Avatar
no up and down movement.
the top of the ball joint that is pressed in doesn't spin
any specific tests for a worn ball joint compared to a new one or just the up and down movement?
Alcatrax30
11-09-2014 05:38 AM
M15
01-19-2007 02:44 PM
Vp Special K
17
01-06-2004 02:08 PM
2camsaam
21
10-01-2003 07:32 PM
munscher
06-16-2003 06:34 PM
Quick Reply: Lower Ball Joint NUT removal and installation
