jdm ecu and usdm ecu VTEC rpms?
Old 02-15-2006, 09:52 PM
SlimBB4's Avatar
Default jdm ecu and usdm ecu VTEC rpms?
alright, i was under the impression that the jdm ecu kicked vtec in at 4500. i had a automatic lsd jdm h22a swap in my last prelude and that was when vtec engaged. my friend just swapped a usdm h22a1 into his lude with the usdm ecu and it kicks in at around 5200. now i just bought a imported jdm prelude and vtec also engages at 5200??? anyone?
thanks
-zAC
Old 02-15-2006, 09:58 PM
Greg H's Avatar
Default Re: jdm ecu and usdm ecu VTEC rpms? (Abstractlude)
I thought they both were the same.
Old 02-16-2006, 04:41 AM
kulrevon's Avatar
Default Re: jdm ecu and usdm ecu VTEC rpms? (Greg H)
I have a jdm p13 ecu and use the stock tach (inaccurate?) and vtec engages at around 5000rpm and always thought the usdm was the same.
Old 02-16-2006, 07:14 AM
IHateJDM's Avatar
Default Re: jdm ecu and usdm ecu VTEC rpms? (kulrevon)
I think its supposed to be 5250 in both usdm and jdm, but it may look a little off on the stock tack.
Old 02-16-2006, 09:58 AM
SteveoBA8's Avatar
Default Re: jdm ecu and usdm ecu VTEC rpms? (IHateJDM)
on my stock tach with my jdm p13 mine engages at 5500
Old 02-17-2006, 07:18 AM
kulrevon's Avatar
Default Re: jdm ecu and usdm ecu VTEC rpms? (SteveoBA8)
just out of curiosity what year car do you have SteveoBA8.
my 92 tach was alot more off then my 95 I believe.
Just seeing if its from car to car thats inaccurate or from year to year.
Old 02-17-2006, 08:13 AM
SlimBB4's Avatar
my automatic lude with the jdm h22a swap engaged vtec at 4500? that would have to be WAY off.
Old 02-17-2006, 10:49 AM
SteveoBA8's Avatar
It's a 94 Base(S). Im still using my automatic gauge cluster.
Old 02-17-2006, 11:00 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Abstractlude &raquo;</TD></TR><TR><TD CLASS="quote">my automatic lude with the jdm h22a swap engaged vtec at 4500? that would have to be WAY off.
your secondaries should open at 4600, and vtec at 5250, unless you're running a chipped ecu, or have a vtec controller.
meheartmycivic
09-01-2010 11:13 PM
chase.vanatta
10-19-2008 06:24 AM
pkolaboy
04-15-2008 08:31 PM
roller3804
12-07-2005 07:34 AM
insomniac791
10-08-2005 04:52 PM
Quick Reply: jdm ecu and usdm ecu VTEC rpms?
