ignition problem, wierd..
okay so first Ill state this prob had benn somewhat sporratic. Sometime it happens once a week,maybe less, or like today 3x.
So I get in my car, put the key i the ignition and turn it to start. Then all you hear is click. Just one singular "click" and all the power to the dash dies. The only way to restore power tothe car is to pull one of the battery terminals. Atleast that was the firt thing I tried when this first happened and so I stick with it.
No fuses blow when this happenes. Sometimes it takes 2 tries of, start, pull batt cable, restart, click, pull cable...then it'll fire up.
Any ideas??
Any ideas??
Re: ignition problem, wierd.. (djbrandonr)
Try cleaning your battery and wire terminals. If not, check your stater relay in the fuse box, maybe going bad, swap it with similar relay. Good Luck.
Re: ignition problem, wierd.. (LudaChris)
my terminals are in bling bling condition right now, Ill have to try and find a test relay if its really the prob
FlewByU352
09-22-2011 12:15 PM
WestDC5
10
01-02-2009 02:49 PM
Punker1234
09-20-2005 07:02 PM
