Huge oil leak??????Please help!!!!!!
Old 12-08-2013, 11:22 PM
  #26
holmesnmanny's Avatar
Default Re: Huge oil leak??????Please help!!!!!!
There's obviously a leak. We can't help you find the leak. Look under the car and see the general area it's leaking at and let us know.
Old 12-11-2013, 07:03 AM
  #27
integra_101's Avatar
a little bit of googling can get you a long way sir. It can be 2 things if its that much oil.
oil cooler which is an easy and cheap fix. or the front main seal which is about 5 hours labour
official oil leak guide
http://www.preludepower.com/forums/s...d.php?t=337508
Old 12-28-2013, 06:26 PM
  #28
Jcrowdy's Avatar
So the issue is the front crank seal. Estimate was 1100$ -_-
Getting everything myself and doing it is 400$
Is this project going to be hell?
I haven't messed with timing belts before.
Old 12-29-2013, 09:24 AM
  #29
minilogoguy18's Avatar
It can be a bitch if you've never done a t-belt before since the cams like to move a bit and the belt is a tight fit. If you don't have the tools you'll probably never get that crank pulley bolt out, even the strongest impact guns don't always get them out, the special tools are needed and doing it by hand while laying on your back gives you no leverage.
Probably best to save your money and let someone who knows what they're doing do it. Best to get all Honda parts and replace EVERYTHING on the timing side of the engine, all seals, belts, water pump and tensioner.
Old 01-02-2014, 07:47 AM
  #30
Jcrowdy's Avatar
I've got a full timing belt kit, all the seals, water pump, everything the shop listed. Cost about 350$. Military discount was nice saved me about 50$ on parts. I have an army buddy who's a mechanic and we are gonna give it a go this weekend.
Any suggestions or tips on this, or anything I might as well do at the same time?
On another note, does anyone know how the front crank seal goes bad? Had it replaced less than three years ago. I went back to that shop, they refused to give me any sort of discount to do it again.
Just wondering if it's something I did or possibly their Shitty work.
Old 01-02-2014, 08:52 AM
  #31
Don Jefe's Avatar
1" OD, 5' long galvanized pipe on the end of a breaker bar does the trick
That is, of course, using the crank pulley tool as well.
Old 01-02-2014, 10:21 AM
  #32
Jcrowdy's Avatar
Thanks for the help guys. I'll let you know how it turns out!
chiaxi2002
04-09-2010 08:56 PM
andreasofpartridgetrail
02-17-2007 10:20 AM
NINJA
08-02-2003 11:56 AM
Sohc Driver
32
07-15-2003 02:46 PM
RAB
07-20-2002 01:01 PM
Quick Reply: Huge oil leak??????Please help!!!!!!
