Help with my pde hf1
Hi I'm trying to figure out exactly wit head I have on my h22a4. I'm looking and thinking of doing some upgrades like im and a Neptune or hondata s300 but not sure on which ones to choose. Thanks any info would be great
Re: Help with my pde hf1
The head will have a stamped code, either P13 or PDE. PDE are fairly rare, so if you have a stock H22A4, its probably a P13.
You should research your mod path based on what you want to do with the car, but a good start is a good programmable ecu setup. Go with whatever your tuner is most comfortable working with, because a baller ecu is no good if the tune is crap.
It's not common but 2000-2001 USDM H22A4 few came with a PDE head. Valve angle is slightly different and slightly smoother casting only on intake side.
Re: Help with Ecu jumper harness
I have a 2001 prelude and am doing s300 trying to figure out wut jumper harness I need obd2a to obd1 or obd2b- obd1 and wits the difference between the two? Thanks
itr1029
02-24-2004 09:35 PM
