h23a dohc vtec ecu question.
Hey guys. Im doing an h23a swap on my da9 and was wondering what ecus i can use for it and what wiring harness to grab also. And also what i would need to convert it to odb1 if nessesary. Thanks!
Re: h23a dohc vtec ecu question.
obd1 p13 ecu will work great, a full tune is even better. obd1 h22 distributor, and the conversion harness from the crank sensor pigtail to the new distributor (assuming you use the h23a engine harness).
or you can get an obd1 h22a1 engine harness and obd1 h22a1 injectors (still need obd1 distributor too)
wireworx I think makes one.
restrictions for tuning? no, same as any other honda motor
head on over to preludepower.com, way more info there especially for h23a swaps
Yes you will need to convert to OBD1 if you are 90-91. 92-93 are OBD1 already.
You will need p28 ecu with a base map of Neptune or Crome of the H23A Vtec Motor. Phearable.net or Xenocron sells the ecus ready to rock for $150.
You will need a Custom Motor Mount Kit if sticking with H transmission.
We sell the ESP DA H22A Motor Mount Kit... PM me. You will need the Packaged Deal with the Traction Bar System to clear the bigger motor. Check out our website for detail how to of the swap and parts list.
Explicit Speed Performance
H2B is a different animal of a swap. Will sit further forward and up... Will have hood clearance issues. Street/Strip H trans... Drag B trans... with H trans motor sits further back like it is suppose to with a lot less work. Yes will still need our ESP DA Traction Bar System whether H2B or H trans for clearance with the bigger motor. PM me.
H2B uses B series mounts
DomkeBoy
08-10-2012 07:58 PM
