H22A4 timing belt sliding off
Old 12-03-2008, 05:56 AM
rasta420's Avatar
Icon6 H22A4 timing belt sliding off
I am replacing the water pump, timing belt, auto tensioner, balance shaft belt, and cam seals on my friends 99 prelude H22A4.
I replaced the water pump and cam seals. I put everything back together, and as I was rotating the crank to seat the belts and double check timing, I noticed the timing belt was sliding off towards the balance shaft belt to the point where it started rubbing against the tensioner for the balance shaft belt. I did a search and could not find anything related to this issue since my friend is retaining his auto tensioner.
I removed the balance shaft belt and timing belt, then rechecked the cam gears to make sure they were not offset from each other. I put the timing belt on again only to have it slide off upon rotation.
I checked the belt itself and it seemed pretty straight. I replaced the brand new auto tensioner thinking maybe it wasn't providing enough tension. After installing the timing belt again, it slid off again. I noticed that where it starts sliding off is from the pulley on the timing adjuster. I took the belt off again, and retightened the bolts for the timing adjuster. I noticed slight play even with all three bolts tightened (the two that go through the water pump and the one through the pulley. There is also slight play where the sleeved section of the adjuster goes over the water pump, which I think is normal as it feels the same way over the old water pump.
Now, what do I check and where should I go from here? I'm still having the same problem and would really like to avoid buying any unnecessary parts.
Thanks in advance.
Old 12-03-2008, 06:14 PM
rasta420's Avatar
ttt HELP PLEASE!
Old 12-03-2008, 06:23 PM
c1v1c98's Avatar
I made a thread with a similar problem a few weeks ago. Check it out:
https://honda-tech.com/forums/showth...402&highlight=
Old 12-03-2008, 06:56 PM
rasta420's Avatar
hey, yeah i actually read your thread while searching a few days ago. i know for sure there is no washer behind the stud that goes through both of the tensioner pulleys. in addition, im not too sure a washer between the two pulleys would help since the belt comes almost halfway off the gears/pulleys to the point where it runs into the balance shaft tensioner pulley...
Old 12-04-2008, 02:58 AM
c1v1c98's Avatar
Originally Posted by rasta420
[b] i know for sure there is no washer behind the stud that goes through both of the tensioner pulleys.[\b] in addition, im not too sure a washer between the two pulleys would help since the belt comes almost halfway off the gears/pulleys to the point where it runs into the balance shaft tensioner pulley...
The SHOULD be a washer behind the stud that holds the pulleys, no? Maybe thats your problem. Also, as I think someone mentioned in my thread, are you sure that the stud that holds the pulleys is straight and not slightly bent?
Old 12-04-2008, 03:10 AM
rasta420's Avatar
remember this is for a h22a4 with the auto tensioner. if there was a washer behind the stud, it for sure wasn't there before either.
can anyone verify this for the h22a4? i know there isnt a washer in the parts diagram.
also as far as that stud being bent, it does not seem bent upon visual inspection. its a completely different looking stud from the one in your thread...the non threaded shaft section of the stud is much bigger and it doesnt look like it could get bent very easily.
i also am still trying to figure out if the play in the timing adjuster is normal with everything torqued down. could this play be coming from the collar in the adjuster? or possibly from a bent stud?
Old 12-04-2008, 12:34 PM
c1v1c98's Avatar
Ahh yea. I was thinking of a manual tensioner, even though I read that you had the auto.
Anyway, good luck.
Old 12-05-2008, 09:56 AM
rasta420's Avatar
Icon2
ttt anyone?
Old 12-08-2008, 09:51 AM
rasta420's Avatar
ttt
Old 12-08-2008, 11:45 AM
moderator emeritus
98vtec's Avatar
is the tensioner installed properly?
Old 12-08-2008, 07:21 PM
rasta420's Avatar
Are we talking about the auto-tensioner? Yes I'm sure I installed it properly. Really just a matter of two bolts and reloading it, then unloading it once the belt is slipped on.
Old 12-09-2008, 09:36 AM
rasta420's Avatar
Icon2
any other ideas? do you think if i added a washer behind the tensioner stud, effectively offsetting the timing belt tensioner pulley further away from the block, this would reduce the sliding of the belt?
Old 12-11-2008, 09:22 AM
rasta420's Avatar
help
please
Old 12-11-2008, 11:19 AM
RWDPRELUDE's Avatar
i ran into this problem twice with the h22a4 motors
the problem with mines was defective water pumps from honda
if you are still having problems try installing the old water pump and turn the
motor over by hand a few times and see if it corrects the belt
Old 12-11-2008, 12:36 PM
rasta420's Avatar
yeah was thinking about the water pump but was trying to avoid changing it again assuming a new pump would be fine...
thanks though will try it this weekend
Old 12-15-2008, 12:50 PM
rasta420's Avatar
so i changed the water pump with high hopes, but the damn belt is still sliding off!
so disappointing...dont know what to do anymore...
Old 12-15-2008, 01:08 PM
90dteg's Avatar
I would like to know as well. I am having this problem with my h22a4 civic.
Old 12-17-2008, 05:46 PM
rasta420's Avatar
ttt
Old 12-19-2008, 07:10 PM
rasta420's Avatar
any other ideas, anyone?
Old 12-19-2008, 08:10 PM
mafia's Avatar
Did you put the balance shaft on and then try to spin it? (the little belt on bottem of timing belt area)
Old 12-21-2008, 08:59 AM
rasta420's Avatar
Default Re: H22A4 timing belt sliding off
yeah i did and the timing belt slides off to the point where it makes contact with the balance shaft tensioner pulley...
Old 12-21-2008, 09:54 AM
team123luder's Avatar
Is the balancer shaft pulley installed? If you removed it, this is causing your problem (behind the crank)
Old 12-21-2008, 03:01 PM
rasta420's Avatar
you mean the pulley that goes on after the crank gear correct?
no it was not installed because the very first time i put back the timing belt and balance
shaft belt, the timing belt was sliding off. it slid off to the point where the timing belt was touching the balance shaft tensioner pulley.
when i tried the old water pump i didnt put back on the balance shaft belt at all.
is this normal that the timing belt slides off and makes contact with the balance shaft tensioner pulley? i dont think so...but i do see a little bit of rubbing on theedge of the old timing belt...
this problem is quite confusing and frustrating!
Old 12-21-2008, 04:11 PM
The balancer shaft pulley is supposed to keep the belt from coming off. Just like the B series has the washer guides. We use the balancer belt pulley. The back of the pulley should be smooth so that when it touches, it doesn't harm the belt.
Old 12-21-2008, 09:52 PM
rasta420's Avatar
so the belt hanging a little bit off of the cam gears is also ok? i guess i wont know if the belt touches the valve cover until i put everything back together...
Joey Mitchell
10
02-02-2019 05:19 PM
Sheela96
12-17-2014 05:23 AM
SmYrE
06-04-2009 03:42 PM
honda94accord
04-10-2007 05:39 AM
blue32
06-01-2005 02:10 PM
Quick Reply: H22A4 timing belt sliding off
