H22A4 Shifting Problems!! HELP!!
I was on the highway driving and then while i was shifting into third gear the car didnt move while pressing on the gas. I tried all of the gears even reverse and its not moving at all. Had it towed home. Before I wasnt able to shift into gear without pressing the clutch now I can go through the gears without pressing the clutch while the car is off. What could the problem be?
Re: H22A4 Shifting Problems!! HELP!!
While the car is on if you can shift through gears (not moving) without clutching. Broken or slipped/disconnected shift linkage for sure.
it could be the cables broken or slipped off of the pins that keep them in place... check your engine bay and then pull off your console and look
trianglegreg
01-04-2006 03:13 PM
89civichatchback
13
07-09-2003 11:23 AM
