H22a Thermostat Temp
I am getting ready to change the thermostat out on my sons Prelude and was wondering what temp thermostat to get? The parts counter recommends the 170 degree thermostat and I guess that is what the OEM says to use. I think my sons is stuck shut since I warmed the car's radiator up to 180 degrees and the thermostat never opened.
The other question was what does temp thermostat does the JDM H22a normally come with?
Re: H22a Thermostat Temp
I believe 170* is where the thermostat begins to open and isnt fully open until 190 or so. either way just get an oem honda thermostat part# 19301-p13-305.
during your test the thermostat should have been at least partially open by 180. it is easy to spot a bad thermostat because the top rad hose will get very hot while the bottom is still ice cold.
170, 180, 19301p13305, 2002, civic, degrees, h22a, honda, jdm, open, part, prelude, temp, thermostat, theromstat
