H22A do I need the vtec pressure switch? and other questions
Old 12-10-2012, 03:16 PM
Crxh22ajdm's Avatar
Icon2 H22A do I need the vtec pressure switch? and other questions
ok im swapping this H22A obd1, I have a P13-J00 (obd1) they told me that with that Ecu I dont need the vtec pressure switch, that jdm ecus dont come with that, I just want to make sure before I have engine inside car, Also What is th Pin # of Oil pressure sensor?
Old 12-10-2012, 08:16 PM
jshaw23's Avatar
Default Re: H22A do I need the vtec pressure switch? and other questions
Not sure about your first question but u can look in the manual that is loaded in the forum there u can find a wiring diagram. Sorry thats all i got for ya.
Old 12-11-2012, 06:20 AM
cvcrcr99's Avatar
I am not running a oil PSI sensor on my swap. H22a motor, Rywire harness, Hondata S300 on a chipped P28 so I can simply turn it off.
Not sure if jdm ecus have it or not. I want to lean towards yes they do, but I am not 100%. My jdm swap came with a vtec solenoid and had the pressure switch. if you need one, PM me and I will sell it to you. The one from my swap is just sitting in my tool box.
Old 12-11-2012, 10:58 AM
moderator emeritus
98vtec's Avatar
Yes, it has a pressure switch. Its there in the event your engine doesn't build enough oil pressure. You can turn it off in aftermarket software but you will get a cel with a stock computer.
Old 12-12-2012, 12:39 PM
Crxh22ajdm's Avatar
ok hmm some P13 are (USDM) and they said that does come with a vtec pressure switch on ecu, And that JDM ecus like mine P13 J00 dont come with a vtec pressure switch, program in the ECU, I just want to make sure.
Is this a question that Ghost can Only answer??
Old 12-12-2012, 07:33 PM
ESP.net's Avatar
Some OBD2 H22/H23 Motors maybe even F20B don't have vtec pressure switches.
However what is there instead is a simple bolt. The Vtec solenoids are the same with or without. Just has a bolt with an O ring in it. If needing a Pressure Switch simply take the bolt out and put a pressure switch sensor
Rywire told me this long ago, I didn't have a pressure switch on motor and he did some wiring to by pass it I do believe. Yes tuning software dont need it.
OBD1 P13 should have it and require it.
Old 12-13-2012, 01:37 AM
holmesnmanny's Avatar
I believe it's the obd2 h22a's that don't have the vtec pressure switches. You can get them from a vtec accord at the junkyard.
Old 12-29-2012, 06:18 PM
lazerus0's Avatar
can anyone give me any info on this? i'm getting tired of the "you aren't looking hard enough" answer, i've been on here an hour and nothing. i have a 92 prelude si h23a1 manual tranny, i want to swap in an h22a manual tranny. does anyone know how to wire in vtec? what axle do i use? what's all this about swapping out the alternator and distributor? which ecu? someone please save the day!
Old 12-29-2012, 06:22 PM
Moderator
snobordboy's Avatar
Have you read the FAQs? There are a few threads in there on h23-h22 swaps, as well as how to wire vtec.
The tranny and axles are identical, aside from gear ratios or lsd models, so you don't need to worry about that.
Old 12-31-2012, 07:34 PM
mondiex's Avatar
you can bypass the switch but splicing the pressure switch and the vtec solenoid switch together. The only negative is; if your cars oil pressure is low, you will still engage vtec.
Old 12-31-2012, 11:34 PM
Crxh22ajdm's Avatar
its eassy, your car harnesz in no vtec, Te vtec solenoid wire to Pin A4 on the ecu computer, Also if you are using A Real p13 JDM you dont need the Vtec oil pressure switch, but if you are using a USDM p13, you need to wire to Pin D6 on ecu. and the black wire just grounded, any more questions just post in here
Crxh22ajdm
01-02-2013 10:51 PM
Lude-venom
11-15-2008 06:26 PM
socialistic
03-15-2008 05:44 PM
lude98SH
01-12-2008 11:39 PM
Quick Reply: H22A do I need the vtec pressure switch? and other questions
