1996 honda prelude h23 probs.. no spark, i think the distributor wires touched? need help!!
Old 10-18-2008, 07:09 AM
lathersr's Avatar
Default 1996 honda prelude h23 probs.. no spark, i think the distributor wires touched? need help!!
Hey I just bought this car off a friend and I put a new distributor on it and it was running good. I didnt tape up the wires and decided to run around the driveway a few times... Next thing you know it dies out and doesnt start.. I get no spark.. also the rotor on the distributor isnt spinning, i checked and it also isnt spinning inside the head of the motor.. What are some of the things I should have checked or replace? I need to get this car going asap and any help would be appreciated... There are 8 wires coming out of the distributor and they were all bare. Thanks, daylen
Old 10-18-2008, 07:44 AM
mattsnooz's Avatar
Default Re: 1996 honda prelude h23 probs.. no spark, i think the distributor wires touched? need help!! (lat
fuses perhaps? What wires shorted out?
Old 10-18-2008, 08:02 AM
lathersr's Avatar
All fuses are good. Im not sure which wires touched...
Old 10-18-2008, 08:22 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lathersr &raquo;</TD></TR><TR><TD CLASS="quote">. also the rotor on the distributor isnt spinning, i checked and it also isnt spinning inside the head of the motor.. </TD></TR></TABLE>
So you're saying that the camshaft itself doesn't spin when you crank
the engine? If that's the case it sounds like you have a timing belt broke.
Old 10-18-2008, 02:03 PM
lathersr's Avatar
I try to spin it with my hands and I cant spin it.. It wont spin when I crank it over either. You really think its the timing belt? Anything else to check?
Old 10-18-2008, 04:37 PM
tmrtwo's Avatar
its a possibility
Old 10-19-2008, 05:52 AM
lathersr's Avatar
The timing belt is still on the pulley not ripped either... where should I start first? has anyone else done this?
Old 10-20-2008, 08:56 AM
kyoso23's Avatar
Did the screw holding the rotor on come loose? That's happened to me multiple times.
integ_lude
10
10-01-2007 04:02 AM
accord93racer
11-08-2005 03:12 PM
monalisa overdrive
04-19-2004 09:07 PM
ELHatchyBlanco
03-16-2004 09:57 AM
Casey
07-28-2003 02:15 PM
Quick Reply: 1996 honda prelude h23 probs.. no spark, i think the distributor wires touched? need help!!
