Diagram of H22 harness
Old 04-07-2004, 07:25 AM
1hotcivicSi's Avatar
Default Diagram of H22 harness
I JUS RECENTLY DID A H23 TO H22 VTEC SWAP IN MY LUDE I AM USING MY H23 HARNESS.. DOES ANYONE HAVE THE LAYOUT OF THE WIRES FOR THE VTEC HARNESS SO I CAN WIRE EVERYTHING IN THAT I NEED FOR VTEC
Old 04-07-2004, 07:29 AM
Sam1am26's Avatar
Default Re: DIAGRAM OF H22 VTEC WIRING HARNESS (1hotcivicSi)
https://honda-tech.com/zerothread?id=818727
that is assuming you have a 93+ prelude
Old 04-07-2004, 12:46 PM
Greyout's Avatar
Default Re: DIAGRAM OF H22 VTEC WIRING HARNESS (Sam1am26)
what if its a '92? Do you just to run a wire from the ECU, or replace the under-hood harness?
Old 04-07-2004, 12:59 PM
Sam1am26's Avatar
Default Re: DIAGRAM OF H22 VTEC WIRING HARNESS (Greyout)
you have to run the wires directly to the ECU, you can find ecu pin outs by serching...
Old 06-24-2010, 06:19 PM
tazh22a's Avatar
i bought a 92 prelude and it has a jdm h22A, and i have been searching and cant find a definate answer, can i run the wire from the solenoid straight to the ECU and im good to go cuz from the looks of it the pressure switch is wired? help please.
harvster87
07-11-2009 06:22 PM
Lude-venom
11-05-2008 07:18 PM
boosted_teg93
10-24-2004 06:54 PM
shadowludeJDM
03-29-2004 09:07 AM
Quick Reply: Diagram of H22 harness
