H22a1 cylinder 4 compression low
Old 09-08-2015, 04:49 PM
Brandon Peters's Avatar
Post H22a1 cylinder 4 compression low
I did a compression test on my h22a1 cylinders 1,2, and 3 were around 225-235 but when I did cylinder 4 it was only around 170-180. I'm pretty new to hondatech and trying to figure out where to start and what I should do. My friend has a leakdown test I could use so I figure that's my next step but would like to hear some suggestions or ideas on what it might be.
Old 09-08-2015, 09:09 PM
backinblue92's Avatar
Default Re: H22a1 cylinder 4 compression low
Well you're obviously looking for variation, which you've found. 10% is considered normal, and youre, what, 25% or so?
U can start by doing a quick valve adjustment. A tight valve can throw #s off but it sounds more like given the discrepancy that you've got a valve or ring issue. Rule out headgasket for most part, as that usual affects 2 adjoining cylinders.
Do a wet compression test, aka a little oil in the low cylinder. If it rises, it's ur rings for sure. If it's static, valve(s)
Old 09-09-2015, 06:44 AM
Moderator
snobordboy's Avatar
<p>If you have access to a leakdown tester, just go ahead and use that, it will tell you if you are leaking out the rings or the head .</p><p>Most likely you have bad rings or blown ringlands, and are going to need a bottom end rebuild.</p><p>Depending on time and finances, it may be faster/ easier to just swap in a JDM engine straight a cross, and pick up a little bit of power in the process. Then you can do whatever with the old engine as time and finances/ desires permit.</p>
Old 09-09-2015, 09:43 PM
holmesnmanny's Avatar
With fairly high numbers I normally wouldn't suspect a leaking head gasket however the 4th cylinder normally is the first cylinder to go. A leakdown test will help pin point. I'm curious if your car has overheated in the past.
Old 10-18-2015, 05:40 PM
Thank you all very much and yes the car has actually overheated in the past before when I was stuck in traffic. Is getting a JDM engine not really very pricey?
nemesis25
01-12-2015 04:17 PM
Team_Coast978
Engine Management and Tuning
06-10-2013 10:58 AM
teefunk01
11-14-2005 07:57 PM
Da1spaz247
11-04-2005 07:57 PM
street dreams
11-21-2004 04:48 PM
Quick Reply: H22a1 cylinder 4 compression low
