cracked cv boot
Old 06-03-2003, 10:24 PM
krnboixshawn's Avatar
Default cracked cv boot
i just noticed that my front left cv boot is cracked and im not sure when it got like that and how. i was wondering if its ok to drive like that cuz i wont be able to take my car in for the shop for another week or 2
Old 06-03-2003, 11:20 PM
RAB
RAB's Avatar
Default Re: cracked cv boot (krnboixshawn)
As far as I know you can drive it around because they'll need to replace you're entire CV Boot/Axel. Its not going to sound good when you turn though because you're losing lubricant from the crack or at least you should be.
Old 06-03-2003, 11:33 PM
DragonBoy's Avatar
Default Re: cracked cv boot (RAB)
Unless you get dirt in the axle and the bearings grind down or you actually lose a bearing then you don't have to change the axle. My right front recently went out and it was half the price to change just the boot. A replacement boot is only $10-$20 but since it's the same process to change the whole axle you pay the same in labor. The shop I went to did a excellent job. They checked and cleaned out the bearings before they repacked the grease and replaced the boot and it's as good as new.
Do not drive on it if you don't have to, because you will be leaking grease all over your rims, brakes, calipers, and wheel well. Not a good thing. Good Luck.
Modified by DragonBoy at 9:55 AM 6/4/2003
Old 06-03-2003, 11:36 PM
DragonBoy's Avatar
Default Re: cracked cv boot (DragonBoy)
BTW, the mechanic told me that it's very common on lowered cars since there is more stress on the cv boot due to the stiffer suspension so it might be a good thing to check for when you clean your rims or during regular maintenance.
Old 06-04-2003, 01:02 AM
another_preluder's Avatar
by the way, does anyone know what a shop should charge to replace cv boots?
Old 06-04-2003, 05:39 AM
Sephro's Avatar
Default Re: cracked cv boot (another_preluder)
I would just replace the whole CV axle. Sure it costs a little more but saves you something down the road. Plus most all CV axles come with a lifetime warranty so if you have problems down the road free part.
DcLs
10-31-2008 10:47 PM
mikeunreal
11-22-2005 08:42 PM
esca
10-27-2004 10:55 PM
mist sITR
09-25-2003 11:02 PM
davidbui
01-13-2002 04:17 AM
Quick Reply: cracked cv boot
