Common coolant leaks
Old 12-09-2008, 09:59 AM
awahl4's Avatar
Default Common coolant leaks
Just wondering on a 98 Prelude where the most common coolant leaks come from so i know what to check out first...car seems to be leaking a little coolant. And want to get it fixed.
Old 12-09-2008, 01:41 PM
preluderemis's Avatar
check the radiator/drain plug from the radiator and radiator hoses as thoses are the most common places...nxt check the thermostat housing (follow your top radiator hose to the engine ) and the water pump housing on the side of the motor
Old 12-09-2008, 01:51 PM
Scheizty's Avatar
Coolant usually leaves a residue that is easy to follow. Can you tell if it is coming from the front or the back of the engine or the radiator?
Old 12-09-2008, 03:27 PM
Kronn 98SH's Avatar
my stock radiator was half plastic and leaked on the top where the plastic meets the aluminum. But more likely than that is what preluderemis suggested.
Old 01-18-2016, 07:49 PM
Dave Gardiner's Avatar
Default Re: Common coolant leaks
I have a 94 prelude vtec. And I am having the same problem as the last guy. Finding coolant on the back side of the motor, above oil filter. No coolant in oil, no pressure in system. please help.
Old 01-19-2016, 09:35 AM
Moderator
snobordboy's Avatar
Pretty much the same as those suggestions above, but the rad can be ruled out.
The main place I have seen coolant leaks is either end of the water pipe on the back of the engine. There is an o-ring holding it tight and sealed on either side, and VTEC cars it is the same one on both sides. Only use a Honda o-ring, I tried many others and they all leaked.
While back there, give the heater hoses a good look over, and the lines to/ from the oil cooler.
The car is old enough that it would be worth checking the oil cooler over as well, it could have developed a leak in 22 years.
92blm92
31
11-07-2017 03:48 PM
poorman's type-r
10-29-2006 09:18 PM
ALLMOTORD16Z6
05-20-2005 03:27 AM
ED6
01-18-2004 06:44 PM
Ri5e
03-18-2002 03:39 AM
Quick Reply: Common coolant leaks
