H22A4 smoking, rebuild questions
Old 07-13-2011, 03:36 PM
usdmftw's Avatar
Default H22A4 smoking, rebuild questions
just thru installing my h22a4 swap and lucky me it smokes to high hell. did compression test and had couple low cylinders that i determined to be the rings or pistons(broke ringlands). had a couple questions about rebuilding it. is it possible like b series to remove the pistons with engine in car by removing head and droping oilpan/scattersield etc.? and what are my piston choices? arent the oem pistons coated? can i use the nippon racing oem type s type as direct replacement(beside having my rods machine for pins)? and are the rings a special type? or just use oem ring? i searched but cant find alot about oem rebuilds, or what to use piston/ring wise to rebuild. its scary when you search oem h22a4 pistons oem and a bunch of ebay listings come up trying to sell aluminum piston w/moly rings. pretty sure that will tear the cylinders up correct? thanks
Blake St.romain
08-26-2018 08:34 PM
Charlie Moua
09-29-2011 08:08 AM
b20beast83
04-22-2010 09:32 AM
W C L
10-17-2005 01:51 PM
Boostless97Lude
04-28-2003 04:30 PM
Quick Reply: H22A4 smoking, rebuild questions
