h23 maf
Old 09-20-2008, 02:39 PM
whatan00b's Avatar
Default h23 maf
Can somebody put up a picture of the maf wiring mine is all messed up the three wires are different colors on eac hside so im all confused.
Old 09-20-2008, 05:01 PM
whatan00b's Avatar
Default Re: h23 maf (whatan00b)
The wire was cut in to basically and I have to halfs one half on the clop its self has 3 wires blue and white colored and the other wires are red yellow and blue and white I need some assitance.
Old 09-20-2008, 05:08 PM
Acidcrakker's Avatar
Go to hondahookup.com and download the helms manuel. Its there and its free.
Old 09-20-2008, 05:12 PM
whatan00b's Avatar
Default Re: h23 maf (Acidcrakker)
Thanks bro. That would be uber helpfull to have small hoosier towns don't know what honda are unfortanitly.
Old 09-20-2008, 09:00 PM
moderator emeritus
98vtec's Avatar
for future reference, we have MAP sensors, not MAF's
Old 09-22-2008, 12:25 PM
whatan00b's Avatar
Ok I've got it wired up now and it runs the same i m sure I wired it up wrong the first time. Could that of killed the sensor? I've replaced the ecu with my spare same results. Should I check the spark plugs to see if they got fouled up?
Old 09-22-2008, 01:38 PM
care to explain what your whole issue is here
If I remember correctly you are doing a swap?
Old 09-22-2008, 02:02 PM
whatan00b's Avatar
The swap is next month. I was just trying to fix up the half *** job the old owner did at wiring his map sensor it was just wires twisted together and electrical taped. I took the wires apart but I came to find out the wires are different colors on each end. So I in a very dumb move tried every combonation of wires to get it working. I now have it wired correctly. But it still idles like crap. I changed my plugs thought I fouled em witch they were. Changed my ecu to a spare I have same model. At it still idles really bad I checked vacuum lines and what not at the idle control screw I ajusted to no results. It hesistates in first gear till 2k and then takes off like normal and drives fine in the other gears. When I let off the clutch in nuetral it drops to 100rpmish and just bounces under a grand till you put it back in gear.
Old 09-22-2008, 02:30 PM
Have you checked your TPS, IACV?
These can also have the same effect on Idle.
Old 09-22-2008, 02:45 PM
whatan00b's Avatar
Not as of yet but I will. It worked fine before I messed with those wires.
Old 09-22-2008, 02:56 PM
Well then there is your awnser. I worked fine before you touched it.
Dont forget to reset the ecu as well.
Old 09-22-2008, 03:14 PM
whatan00b's Avatar
Yeah its what I figured but I didn't know if not haivng it connected would mess with other stuff.
Old 09-22-2008, 11:02 PM
Hawkze_2.3's Avatar
MAF = Mass Air Flow sensor
MAP = Manifold Absolute Pressure sensor
Honda Prelude = no MAF, only MAP
Old 09-23-2008, 05:10 AM
whatan00b's Avatar
Default Re: h23 maf (Hawkze_2.3)
Yes I know this now. One last question I bought a firewall mounted map on ebay but mine is a intake mani mointed one does that really matter?
Old 09-23-2008, 07:57 AM
Hawkze_2.3's Avatar
All that matters is that you supply it with vacuum and plug in the connector.
Old 09-23-2008, 08:39 AM
whatan00b's Avatar
killer
Old 09-26-2008, 01:39 PM
whatan00b's Avatar
Yep that was the problem seems to be running just fine after reseting the ecu thanks for the help fellas
Ryan559
09-02-2012 08:46 PM
Kahuna9889
04-05-2009 05:57 PM
pearl
11-09-2006 10:33 PM
flip1199
12-28-2003 11:12 PM
Quick Reply: h23 maf
