1997 Prelude No Crank No Start
Old 10-27-2015, 08:36 PM
300k's Avatar
Icon5 1997 Prelude No Crank No Start
Issue with starting 1997 Honda Prelude 5spd:
Key in ignition, turn key, no crank.
Things I have tried preventatively:
Tested ignition with non-chipped key. Override appears to work properly.
Changed battery cables.
Disabled clutch override switch on pedal. Also checked to see if the button stopper on the pedal assembly that tells the clutch override the pedal is depressed. Everything is intact.
Turn Key, no crank. Anyone have this problem?
Old 10-28-2015, 06:16 PM
backinblue92's Avatar
Default Re: 1997 Prelude No Crank No Start
http://www.preludeonline.com/f60/engine-wont-turn-over-crank-happened-suddenly-268853/#/forumsite/20494/topics/268853?page=1
Old 10-28-2015, 10:59 PM
300k's Avatar
OK, got it figured out!! Took the starter to O'Reilly and the hillbilly behind the counter asked what the problem was, and I told him I'd like my Honda starter tested and his response was:
"That's your first problem!"
I found the dodge neon in the parking lot and slashed the tires (JK!!) before I headed off to the O'Reilly in the HOOD!!
The guy there was awesome! Tested the starter. Passed. Tested again, Passed, and said, "I'm gonna test it one more time to be sure." FAILED and never passed again! Went up to Honda with a Honda uniform I found at a thrift store (name tag says Jerry) and they gave me a discount on a new starter!! YUP!
s.langley
02-03-2019 06:31 AM
seane51
01-17-2014 03:50 PM
brandejo
09-22-2013 03:41 PM
EFS463
08-14-2013 05:10 PM
dirtygerman
06-17-2011 07:04 PM
Quick Reply: 1997 Prelude No Crank No Start
