F20b piston and rod compatibility
Old 03-07-2017, 02:38 AM
manueel423's Avatar
Default F20b piston and rod compatibility
I have an f20b in my honda prelude and i need to know which rods and pistons are good thanks for the help
Old 03-07-2017, 02:45 AM
TimiK's Avatar
Default Re: F20b piston and rod compatibility
aftermarket, oem? for what purpose?
Old 03-07-2017, 01:11 PM
manueel423's Avatar
like h series or other f series engines etc
Old 03-07-2017, 08:49 PM
TimiK's Avatar
oem or aftermarket?
you want to raise your compression or what?
Originally Posted by JDogg
there is nothing off the shelf for that engine, everything will have to be custom made.
easiest thing is to use h22a4 crank, h22 rods and custom pistons.
bisimoto has f20b rods but theyre 500, for pistons maybe K20A? dont know which rods you would need with em
theres nothing for f20b directly so you gotta be creative and do research
Old 03-09-2017, 07:19 AM
Premium Member
Aradin's Avatar
Last I checked bisi didn't carry the rods anymore since he's pretty much done with Hondas. OP, you may be able to call and get a one-off set made if he still has the specs.
For the most part there are no direct replacement forged components for the F20B. There are solutions to that problem and this issue has been discussed many times over. Search.
civicmotorhead
10-24-2009 12:25 AM
crx87
12-08-2008 11:08 AM
DarkTeg94
12-26-2005 10:30 PM
Aeka GSR
02-18-2005 05:05 AM
Quick Reply: F20b piston and rod compatibility
